Re-routing Coolent Lines Into Throttle Body
Old Jun 15, 2012 | 03:22 AM
Cambird Z/AM's Avatar
Car: 1991 GTA Trans AM
Engine: 305 TPI V8
Transmission: 4-Speed Automatic (700-R4)
I bought a pair of headers from a guy and he was telling a few tricks to gain a few more horse' out of my 305 TPI. He had brought up that by changing some coolent lines around, so your throttle body is getting cool water, not hot water, you could gain almost 10 HP. He said i would have to invest in some new rubber lines, which is no big deal.
Has anybody done this trick? Does It Work? Is it worth it? And what lines do i re-route? I use the car as a daily driver, but to gain 10 more HP, i think i wouldnt harm anything.....i hope!
Car is a 91 GTA Trans AM 305 TPI, with A/C and headers!
Old Jun 15, 2012 | 03:53 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Re-routing Coolent Lines Into Throttle Body
Yes everyone does it because they "think" they will get free Hp.
No it doesn't make any difference ; feel how hot the rest of the intake is after driving for 1/2 an hour so having a cool TB makes little difference to temp of air going into the engine
But it cleans up the front of the engine , makes it easier to work on and removes a couple leak potential spots
And what lines do i re-route? ...... but to gain 10 more HP, i think
Get some heater hose and run it from the coolant outlet on the front of intake all the way to the heater bypassing the TB all together.
or cheap out and buy only enough hose and a connector to join the hose from heater to the spigot on the intake
Old Jun 16, 2012 | 11:53 AM
PDX88IROC's Avatar
Car: 1988 IROC
Engine: 5.0 TPI
Transmission: 5 spd T5
Axle/Gears: G80,G92,3.45
Here are a few threads that discuss the TB coolant bypass:
https://www.thirdgen.org/coolantbypass
https://www.thirdgen.org/forums/tpi/...at-1988-a.html
https://www.thirdgen.org/forums/tpi/...nt-bypass.html
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
lakeffect2
Aug 23, 2015 08:44 AM
mdtoren
Aug 16, 2015 05:45 PM
