TPI swap
Car: 89 Iroc
Engine: 5.7 Tpi
Transmission: WC T5
Axle/Gears: 9 bolt/stock
TPI swap
I'm swapping my TBI to a TPI system that I picked up and I have a question.....I did research on it but, I still am not positive. I was going to convert my TBI harness to run the TPI for MAP/SD but....I only have the 91 stock TBI ecm and a 87 TPI ecm....can I use either of those to run that harness converted to MAP/SD TPI? Anyone's help would be AWESOME!
Transmission: T-5, TH350, T-5
Re: TPI swap
This was in the stickys. It shows you how to repin and rewire the TBI harness for TPI.
https://www.thirdgen.org/forums/tpi/...d-density.html
Car: 89 Iroc
Engine: 5.7 Tpi
Transmission: WC T5
Re: TPI swap
I already wired everything else up but the ECM and all I need to know is if I HAVE to use the 7730 ECM or if I can get away with using the 7165 ECM or if there is some way to use the 91 TBI ecm.
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Car: 89 Iroc
Engine: 5.7 Tpi
Transmission: WC T5
Re: TPI swap
I have the 165 ecm.....burn off and Maf relays. The ecm and relays were out of a 87 iroc. I also have the 87's harness....so me and me friend were going to repin and add the connections for the Maf off of the 87 harness. Pretty much building a harness lol.
Sanjay
Aug 12, 2015 03:41 PM
