89 firebird crank no start
Old Jun 28, 2012 | 10:54 PM
acechase99's Avatar
ok so heres whats going on i have spent about a week just looking through post and see many related problems but still no solution so here it goes.
89 firebird formula 350 MPFI auto trans. I recently bought this car and the prior guy did a hack job to it so im trying to bring it back to life.
I replaced the fuel pump, fuel filter and relay as a first place to start cuz the pump was not priming when turning the key. still no prime but it will prime if I run a hot wire to the lower left corner of the ALDL (i believe G terminal) It also gets around 45psi to the fuel rail when trying to crank without manually priming it at the ALDL. I also replaced the fuel injectors thinking it was a good idea after the guy said he would pour gas and starter fluid in the intake but still nothing. It acted like it wanted to on the first crank then nothing. all the fueses are good even the one by the batery and I get spark. plugs are in right order and cap and rotar are clean. timing looks go when set to top dead center(term might be a little off). next to to try and figure out the vacuum mess going on. I think thats about it I picked up a OHM meter or volt meter to try and test out some wires but im still trying toteach my self how to use one. any one Got any ideas I missed? probable try a ECM when i get a chance to go to the junk yard, any way to test that? Oh yea no codes come up but I have not had it started since replacing the battery.
Old Jun 29, 2012 | 01:55 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: 89 firebird crank no start
That would be NO SPARK!
Do you have strong spark at the plugs?
Old Jun 29, 2012 | 07:28 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Old Jun 29, 2012 | 08:18 AM
86T/A_Ram_Air's Avatar
Car: 91 Trans Am
Engine: 355 TPI
Transmission: Built T-5
First and foremost chances are you have a bad fuel pump relay for the priming issue. then you need to make sure your spark is strong. if you have a weak spark it could cause a problem, so check the spark at the coil and then at the plugs, and go from there
Old Jun 29, 2012 | 10:02 AM
acechase99's Avatar
sry i miss wrote that some how he would pour and spay it into the intake and it would idel but die when given gas. it seems to have stong park at the coil and seems a little week at the plugs. probable just going to repace all that for the hell of it.
the relay is new but ill pick up a different one today and try it, and hopfully figure out all these **** on the voltmeter so i know what these numbers mean
thanks for the help lets see what else we can find out today
Old Jun 29, 2012 | 08:28 PM
acechase99's Avatar
I need to quite writing so early or late at night. He would spay fuel in the intake, didn't not mean some how I know how he did it obviously.
But on the other note was screwing around with the car a little today and got no where but i replaced the fuel relay again no go. and the wires seems like a little bigger spark but still nothing it hickuped once but then nothing. hooked up the fuel pressure test again just for kicks and I am not getting any pressure now. any more ideas before i decide to go carb
Old Jun 29, 2012 | 09:55 PM
JP86SS's Avatar
Car: 86 Monte SS (730,$8D,G3,AP,4K,S_V4)
Engine: 406 Hyd Roller 236/242
Transmission: 700R4 HomeBrew, 2.4K stall
Axle/Gears: 3:73 Posi, 7.5 Soon to break
If the pump doesn't prime when key on, check the ignition module and pickup coil.
No ref pulse will cause the pump to not run.
There is a two second or so run time for each pulse.
If module is crap (or intermittant) that could cause your problem.
Wet and fouled plugs won't help either.
Get a module and/or a pickup coil, clean the plugs and try again.
Old Jun 29, 2012 | 11:43 PM
acechase99's Avatar
ok thanks I will run up to the store tomarrow and let you know any more ideas? anyone have pics of the vacuum lines off the egr and fue reg i want to mke sure i have everything correct over their thanks?
Old Jun 30, 2012 | 12:09 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
The ECM operates the pump relay (and pump) for 2 sec to prime the rails when the key is first turned on;
before the engine even turns over to generate the dist ref pulse you mention
In any case his fuel pump should be running from the oil pressure switch any time the engine is cranking over,
12V applied to terminal G of the ALDL will make the pump run full time to confirm if pump is working and making pressure
Old Jun 30, 2012 | 02:07 PM
acechase99's Avatar
is their any way to test the ECM or should I just replace to ICM and go from there
Old Jul 2, 2012 | 06:55 PM
acechase99's Avatar
ok picked up a ICM and some cleaner for the IAC and MAF sensor lets see if we can get some action
Old Jul 2, 2012 | 08:56 PM
acechase99's Avatar
installed the ICM and cleaned carbon off the IAC. the engine now turns over but will die right away unless giving it gas to about 2500 to 3000 RPM and getting code 34 MAF. could a MAF sensor cause the engine to do this or am i looking at a different problem at about 150 $ a piece i kind of want to double check or if their is a way to by pass it
Old Jun 26, 2013 | 09:15 PM
rocketforme's Avatar
Car: 1989 GTA
Engine: 350 tpi
Did you ever resolve your car problem? I think I have the same issue as your description and was wondering if you got your car working again.
bryan623
Mar 22, 2021 06:43 PM
Caspar
Jun 19, 2016 11:19 PM
TheExaminer
Aug 26, 2015 04:59 PM
Tonyy_z
Aug 12, 2015 07:20 AM
mizz0313
Aug 12, 2015 06:45 AM
