lt1 throttle body?
Car: 1989 Formula Firebird
Engine: Swapped 350 TPI speed density
Axle/Gears: 2.73 (soon to be 3.42)
lt1 throttle body?
Will a lt1 throttle body bolt on a 91 350tpi intake?
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: lt1 throttle body?
Bolt to yes, work no not without modifications to the iac passage. the triangle shaped area of the iac passage on the back of the tb needs to be notched so manufold vacuum can reach the iac. you would need to modify the linkage for a automatic tv cable as well.
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
i was looking at a caprice with the lt1 and was planning to attempt to machine the divider between the throats out and make a new throttle plate for more air flow...since i have more time and access to a machine shop than money im wondering if this would work like having a bigger throttle body throat
or are the throats on the lt1 bigger in the first place
Terrell351
Jun 13, 2021 01:13 PM
mdtoren
Aug 16, 2015 05:45 PM
