86 LB9 reassembly help
Car: 86 IROC-Z
Engine: LB9
Axle/Gears: limited slip disc
I got an 86 camaro with the lb9 that the previous owner began but never finished a head swap on. The head and lower intake are installed. I need help with the driver side exhaust manifold and accessory bracket installation and the TPI reassembly. I have repair manuals but the pics in them suck! Any help would be GREAT!!! Pictures would help a lot. This car looks to be 90% stock so stock is what I'm looking for.
Thanks.
Thanks.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Car: 86 IROC-Z
Engine: LB9
Re: 86 LB9 reassembly help
Thanks that looks like it will take me a long way.
Now where does the wiring harness go? Ie inside or outside the runners.
Engine: Lb9
Transmission: M20
stock outside of the runners, it looks better to run it on the inside for aesthetics.
Engine: Lb9
Transmission: M20
I can't recall if the alternator wire need to be rerouted or not.
Car: 86 IROC-Z
Engine: LB9
Car: 79' LT1 olds cutlass/ 87' IROC
those diagrams and pictures are insanely helpful. you should post those in the tech data section. i would have loved this a few weeks ago when i was putting together my front end.
Car: 86 IROC-Z
Engine: LB9
I'm happy to report that the car has been running great for the last couple of weeks! Thanks again!!
