Upgrade heads
Old Jul 25, 2012 | 12:32 AM
TA-Rocks's Avatar
Car: 87 GTA, 99 VFR800
Engine: 5.7 TPI wrong heads , 781cc
Axle/Gears: 3.08, msg me if u hav 3.42 4 sale
Upgrade heads
I want to upgrade the heads in my 350 which has 305 heads. I have read a number on the head that read 14102187 and read on the back of the engine 5.7LC. I suppose that is telling me that I have 305 heads on a 350. I would like to upgrade the heads and didnt see the threads discussing the upgrades.
I want to see which heads are possible. Can I use a LT1 set on the L98? I dont suppose I can use the LS1. Which cars can I use for donors then? I would rather buy a used set. Later on I will probably upgrade the engine to LS1 anyway, so I will want to upgrade this one cheaper.
I have taken this car to the track and found that it had a trans problem. I ran it five times and ran in second gear after two runs. It ran good, however. It ran 14.35 first run and progressively worse then.
gta90
Sep 15, 2015 04:00 PM
509 camaro fan
Sep 6, 2015 10:43 AM
NinjaNife
Aug 23, 2015 11:49 AM
86White_T/A305
Aug 17, 2015 12:16 AM
