Engine running rough and stalls in gear
Old Aug 3, 2012 | 10:32 AM
neitzelm's Avatar
Car: 1985 Z28 Camaro
Axle/Gears: Posi 4.10
Hey everyone, I've been having a problem getting my camaro (1985 TPI 305 Auto Tranny) to be even drivable this summer. Basically when I drop it into reverse or drive, it will bog down in RPM's and stall a lot of the time.
I've replaced:
spark plugs
spark plug wires
dizzy cap
ignition module
fuel injectors
I have a mild VooDoo cam in it (about .465 lift 112 lsa), 255 fuel pump, 300lb valve springs, stock heads and headers.
I have the timing set at about 10-12 degree BTDC....I've adjusted the idle screw so the car runs near 1,000-1,200 RPM when idling in park.
Vacuum seems ok for putting in a mild cam (10-14 vacuum). I've checked for leaks but I think I have everything hooked up properly.
I don't have any check engine lights anymore, I got those all to go away finally. Any ideas????? I'm very frustrated in all of the work I've done and still can't drive it!!
Old Aug 3, 2012 | 10:43 AM
Guest
Guest
Posts: n/a
Re: Engine running rough and stalls in gear
Only thing I can think of is the throttle position sensor. Same thing happened to mine, replaced the TPS and bingo. Granted, that was when she was stock so I don't know
How applicable it is to you. Cost about $80 and ten minutes of my time.
Old Aug 3, 2012 | 10:57 AM
neitzelm's Avatar
Did your check engine light come on for the TPS? I think the TPS is literally the only thing I HAVENT replaced in that car haha
Old Aug 4, 2012 | 12:16 AM
Guest
Guest
Posts: n/a
No. There was no check engine light. She would just stall out at idle like she was starved for fuel and would act like a manual car does when you don't give it enough gas on acceleration. Just shudder and weeze then stall.
Old Nov 4, 2012 | 06:49 PM
cfs2chvy96sub's Avatar
Car: 91 camaro rs v8
Engine: 305,5.0 liter
Axle/Gears: 10 bolt 355
iv replaced my moduler also ,the guy before i bought it replaced plugs an cap an wires an starter,i was thinking my distributer or tps ,but reading up on here they say check all vac lines also
Vintageracer
Jan 10, 2020 05:33 PM
theshackle
Mar 5, 2017 06:37 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
camaroken83
Aug 10, 2015 11:35 AM
