305 TPI wont idle.
Old Aug 3, 2012 | 08:12 PM
penguinpanda0's Avatar
Car: 1987 IROC-Z Camaro
Engine: 305 LB9
305 TPI wont idle.
Has trouble running unless I tap the throttle a little bit. It runs pretty much without issue in higher RPMs. The vacuum line to the fuel pressure regulator is chewed up, so that may be my issue. A new fuel filter is on its way in, but other than that, I'm thinking about replacing the Idle Air Control Valve, and if that doesnt do the trick then the Throttle Position Sensor will be replaced next, and if THAT doesnt do the trick then I'll replace the EGR valve. If there's anything I'm missing, any help is appreciated. (=
Old Aug 4, 2012 | 09:37 PM
Engine: 305 LB9
Re: 305 TPI wont idle.
Replaced fuel filter and now it idles for around 3 or 4 seconds before stalling.
Old Aug 4, 2012 | 10:21 PM
PhoenixFirebird's Avatar
Car: 1989 Firebird Formula
Engine: 385
Transmission: Full Manual TH350
Axle/Gears: Moser 9" 3.70
Fix the vacuum leak that's known and see if that cures it. Other than that, get a can of starting fluid/carb cleaner/whatever, and spray it around the engine in different spots. If your RPMs surge when you spray a certain area, there's your vacuum leak.
Old Oct 27, 2012 | 08:25 AM
310cid's Avatar
Car: 92 camaro
Engine: 406
What was problem and was it a leak
Old Oct 28, 2012 | 01:46 AM
RestLess92's Avatar
Car: 89 Z28 T-Top
Axle/Gears: 3.27 posi
Did you fix the problem. I have the same problem on my 350 tpi right now. But it will stay on when its warmed up.
Old Oct 28, 2012 | 03:01 AM
jeff_blake's Avatar
Car: 86 Iroc + 83 Firebird
Engine: Iroc 305 TPI, Firebird 305 4bbl
Transmission: 700r4 in both.
Axle/Gears: Iroc 3.27 Firebird 3.23
i'd guess vaccum leak, mine had a cracked line under the front of the plenum, and one hiding in the back. spraying starting fluid is a great way to find em as mentioned above.
Orr89RocZ
Apr 25, 2016 08:28 AM
gta90
Sep 15, 2015 04:00 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
