Cold start injector removal
Old Aug 15, 2012 | 09:22 PM
Slayze's Avatar
Car: 87 Trans Am
Engine: 355 Carb. Nitrous 100 shot
Transmission: TCI Performance Trans. 350 Turbo
Axle/Gears: Borg & Warner 9 bolt 3.70 gears
Hello me and my friend took my 1987 TPI out of my Trans Am and swapped it for a Carb'ed 350. We do want to re-use the 305 TPI motor/ecm set up in another car. What we were wondering was about the cold start injector. We know we can plug it, but does anything have to be done to the ECM to make sure the car will start? I dont think my car had the anti theft system if that matters and as mentioned before it was an 87 trans am 305 tpi. Any help/instruction on the topic would be great. Thanks in advance.
Old Aug 16, 2012 | 03:09 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Cold start injector removal
CSI is a independent standalone system not connected to anything else.
It only gets power when the engine is cranking over and has a thermo switch with a timer that controls when and how long the injector sprays.
As soon as the engine gets to a certain temp it is no longer in effect
when cranking
Plug hole and delete wiring to the thermo switch ( front of intake ) then to starter terminal
CSI thermo switch is the brass unit with hex head to the left of the
sensor circled ( the CTS )
However ,
if you live somewhere where it gets cold you will want the '89 305 MAF TPI tune for the ECM that gives extra fuel cold start through the 8 injectors
( same as what the CSI did on early engines )
Old Aug 16, 2012 | 03:58 AM
Slayze's Avatar
Car: 87 Trans Am
It does get cold in the winter here, but its gonna be a summer car only. Thanks for such an awesome response with a pic and all. Thanks again.
Old Aug 16, 2012 | 04:14 AM
Arvizu9618's Avatar
Car: 1985 IROC-Z Clone
Axle/Gears: 3.23 Rear Disc
I thought Cold Start Injector was in vicinity of Injectors 5 and 7 on the intake???
Old Aug 16, 2012 | 04:24 AM
Slayze's Avatar
Car: 87 Trans Am
It is. the circled part of the pic is for wiring to the thermo switch. The injector isnt pictured.
Old Aug 16, 2012 | 09:01 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
I never had a problem with cold starts in summer with the CSI deleted and stock tune,
even in mild winter just took a little longer cranking over to fire up.
jklein337
Sep 19, 2018 06:23 PM
Wade787b
Sep 29, 2015 01:15 PM
apie2546
Aug 10, 2015 05:43 PM
mustangman65_79
Aug 8, 2015 12:07 PM
drathaar907
Aug 6, 2015 04:20 PM
