1987 L-98 Oil
Old Aug 25, 2012 | 09:02 PM
cmk-2's Avatar
Car: Corvette ZR-1
Engine: LT-5
Transmission: 6 sp
1987 L-98 Oil
Hello everyone, My 60,000 mile Stock Iroc-z L-98 Do I need to add Zinc to the engine oil these days with the new low/no zinc oils?
Thanks for any help,
Old Aug 25, 2012 | 09:04 PM
red rock's Avatar
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
Re: 1987 L-98 Oil
No, just use a good quality oil. Me personally, I use Valvoline 10w30. Use what ever you like.
Old Aug 26, 2012 | 09:09 AM
cmk-2's Avatar
Car: Corvette ZR-1
Engine: LT-5
Transmission: 6 sp
Re: 1987 L-98 Oil
Thank you. I'm adding it to my 1978 T/A with a Pontiac 400 but was not sure about the 87.
Old Aug 26, 2012 | 09:29 AM
red rock's Avatar
Car: 1987 iroc
Re: 1987 L-98 Oil
The claim with zinc is, it has a better lubricating quality on high performance engines, but then some claim it's not so good on emission equipment. I think if you change the oil regularly with a quality oil, you will have long engine life. I have 158,000 on my truck and it doesn't smoke or burn oil. My Friend has 375,000 on a 1994 chev truck and doesn't burn or smoke oil. It all depends on you maintenance schedule.
Old Aug 26, 2012 | 10:19 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: 1987 L-98 Oil
You can run zinc it wont hurt, In fact I run a solid roller and Crower told me to run zinc oil because it helps the oil cling to the parts a lil bit better. I run Shell Rotella T..
Old Aug 26, 2012 | 11:47 AM
MaxpowerTA's Avatar
Car: 1992 T/A convertible
Engine: LB9 TFS175heads Ebase/accel runners
Transmission: T5 5spd
Axle/Gears: 4.11
Re: 1987 L-98 Oil
Zinc is a high pressure additive, it is definitely needed for older flat tappet non roller cam engines to keep the cam lobes from going flat (like on a 1978 pontiac 400 or pre 86ish chevy smallblocks) but your 87 should have a roller cam so a zinc additive is not necessary.
Old Aug 26, 2012 | 09:02 PM
hdis2002's Avatar
Car: 87 IROC Z
Engine: 5.7
Re: 1987 L-98 Oil
The 87 5.7 is not a roller. FYI. I add zinc to mine. Better safe than sorry.
Old Aug 26, 2012 | 09:25 PM
red rock's Avatar
Car: 1987 iroc
Re: 1987 L-98 Oil
The 87 5.7 is a roller. I have one. If your's isn't a roller, you don't have the original motor in it. Read this;https://www.thirdgen.org/1987-chevy-camaro
Old Aug 26, 2012 | 09:55 PM
cuisinartvette's Avatar
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
Re: 1987 L-98 Oil
Todays oils have plenty of zinc in them
Good film strength look at Valvoline VR1 good stuff
Old Aug 26, 2012 | 10:36 PM
MaxpowerTA's Avatar
Axle/Gears: 4.11
Re: 1987 L-98 Oil
"The 87 5.7 is not a roller. FYI. I add zinc to mine. Better safe than sorry."
I had an 87 GTA at one time and it definitely was a roller cam motor, I believe 87 was the first year for rollers in the F-body. If you have a roller you dont need zinc additive.
Old Aug 26, 2012 | 10:40 PM
MaxpowerTA's Avatar
Axle/Gears: 4.11
Re: 1987 L-98 Oil
"Todays oils have plenty of zinc in them" The only modern oils that have "plenty" of zinc in them are the expensive racing oils and maybe some specialty oils made expressly for classic cars. Even the diesel oils have had most of the zinc removed from them, The EPA claims it poisons cats (not the furry kind).
Old Aug 27, 2012 | 01:04 AM
BumpaD82's Avatar
Car: 1982 Z28 & 1967 RS & 2002 Z28
Engine: 388 ci SB / 454 ci BB / LS1
Transmission: 4 speed / TH350 / T56
Axle/Gears: '91 "1LE" rear, posi w/ 3.23's
Re: 1987 L-98 Oil
More info than you'd ever want about oils:
http://www.bobistheoilguy.com/forums/ubbthreads.php
AS to your question .. I run SOME zinc
Old Aug 27, 2012 | 06:43 AM
hdis2002's Avatar
Car: 87 IROC Z
Engine: 5.7
Re: 1987 L-98 Oil
I stand corrected. The PO replaced the cam. One of the receipts I got with the car was for a non-roller cam. I mistakenly assumed the engines were non roller. Sorry about that.
Steve
F.I. 57 Belair
Aug 23, 2021 01:09 AM
TX-SleeperC5
Feb 24, 2016 01:34 PM
Magman
Sep 13, 2015 12:14 AM
timonator
Sep 11, 2015 05:11 PM
scottmoyer
Sep 7, 2015 07:06 PM
