Intake plenum gaskets?
Car: 1989 Pontiac GTA/2007 TrailblazerSS
Engine: 350 L98/LS2
Transmission: 700-R4/4L70E
Axle/Gears: 3.27/4.10
Just replaced my plenum and runner gaskets this summer, now I think I gotta pull it all apart again cause I think my lower intake seal might be pissing out oil. That smaller portion on the rear of the intake by the distrib.
So my question is do I have to replace my plenum gaskets AGAIN after just doing them?
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Re: Intake plenum gaskets?
I've reused the same plenum gaskets for 10 years and I've had that plenum off a hundred times. Unless they tear apart when you remove the plenum, you'll be fine.
Engine: 4++,350 & 305 CIs
I spray pam cooking spray or a light oil on the paper air only gaskets. It helps keep them reusable.
1992 Trans Am
May 10, 2023 07:19 PM
ambainb
Apr 25, 2016 09:21 PM
92projectcamaro
Jan 18, 2016 08:00 AM
