loud rattling?
Old Sep 19, 2012 | 09:07 PM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
loud rattling?
alright..
so it doesn't rattle when its cold just gradually gets a bit louder as it gets hotter..
also, the idle is really rough but gets a little less rough as it warms up..
stumbles on sharp accel..
what could be doing all this??
Old Sep 20, 2012 | 09:39 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
Re: loud rattling?
????????bump???????????
Old Sep 21, 2012 | 11:23 AM
itsMikey's Avatar
Engine: 5.7 350 TPI
Re: loud rattling?
no one? guess ill just run it down to the shop i take it too.. :/
Old Sep 24, 2012 | 02:20 PM
bestracing's Avatar
Car: 86 T/A - 70 Z28/RS
Engine: Broke - 350
Transmission: 700R4 - M22
Axle/Gears: G80, 2.73 - ZQ9 G80 4.10
Re: loud rattling?
Have you done anything to the exhaust? I've seen some y-pipes that hit the lower fender bolt and cause knocking.
This is really hard to troubleshoot over a message board but first thing to do is jack up the car. Put floor stands under it for safety. Crawl under the car and look around and see if the pipes are close to anything. If you don't find anything that way then, with the exhaust cold, grab the exhaust and shake it. I also found a rattle buy tapping the y-pipe with a rubber mallet. I had a bad clamp on the crossover pipe.
Good luck
Old Sep 24, 2012 | 03:16 PM
Richboll's Avatar
Car: 89 Black IROC-Z convertible
Engine: 305 TBI
Re: loud rattling?
I've got a rattle in my converter at idle. Can you describe the rattle that you have and approximately where it's coming from? Does it get louder with speed? I think we need a little more info to try to help you locate the problem.
Old Sep 24, 2012 | 06:05 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
Re: loud rattling?
Good luck
didnt even think about that..ive slammed my exhaust so many times i may have loosened something..
i know my trans may need a rebuild so thats possible also..it sounds like its coming from right under the radio/shifter area
Old Sep 24, 2012 | 07:46 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
Re: loud rattling?
alright so i actually grew a brain and looked under the car today i can see whats rattling, it is in fact.....my exhaust haha..thanks for the suggestion, bestracing.
now, what is causing my bouncy idle??
new maf..new o2..new just about everything..the only possible thing i can fathom is my spark plugs..what do you guys think?
Old Sep 24, 2012 | 08:16 PM
Richboll's Avatar
Engine: 305 TBI
Re: loud rattling?
Check for a vacuum leak. A split hose will sometime do that.
Old Sep 24, 2012 | 10:05 PM
bestracing's Avatar
Engine: Broke - 350
Re: loud rattling?
I agree with above. Also you say almost new everything, did you clean out the passage for the IAC (idle air control) when you were working on the throttle body? I've seen build up on throttle bodies do similar things as well.
jrdturbo
Mar 31, 2016 02:58 PM
loud91rs
Oct 5, 2015 10:05 PM
luvofjah
Sep 26, 2015 08:28 PM
GouldyGTR
Sep 7, 2015 09:05 PM
Ian Irvine
Sep 4, 2015 08:08 AM
