305 TPI Fuel pressure gage
I borrowed a pressure gage to test my TPI regulator. The pressure tap is right under the plenum and behhind MAP sensor. there is no was i can attach this gage. is there another tap I am missing?
92 Camaro TPI 305.
thanks
92 Camaro TPI 305.
thanks
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
Re: 305 TPI Fuel pressure gage
There's only one that I know of. Maybe you can take the map sensor off the bracket temporarily and that will give you enough room? I installed a permanent indicator and remember that it came with some kind of mod for the map sensor bracket.
Transmission: Pro-built 700R4
Nope. You're not missing anything. Its a pain in the rear to get to. I got a 90* adapter from Actron to attach a guage to. I'm now in the process of removing the valve from the schrader valve and attaching a 90* fitting from autometer so that I can just install my fuel pressure guage and not have to worry about that impossible spot to connect things to.
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
This style gauge adapter
http://www.summitracing.com/parts/RUS-670290/ ( and a -4 AN cap to seal the open end )
is easier to install ( and remove if required ) ,just turn the blue nut
Some 90 degree fittings require dismantling the intake to get enough swing room to wind them in place
This is the one I went with to install my gauge:
http://www.summitracing.com/parts/ATM-3274/
It can be installed without moving anything.
R3500
Aug 17, 2015 12:16 PM
Sanjay
Aug 12, 2015 03:41 PM
