IAC valve
Old Oct 25, 2012 | 03:06 AM
Eightyninef's Avatar
IAC valve
1989 LB9, IAC valve, with the T5. All stock motor.
I see 2 listings:
AC Delco 217-437
AC Delco 217-415
which one is it ?
Old Oct 25, 2012 | 03:16 AM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Re: IAC valve
415 is TPI
437 is TBI
Old Oct 25, 2012 | 03:17 AM
Re: IAC valve
But they both say VIN F on rock auto, and parts geek.
LB9 is vin F
Old Oct 25, 2012 | 06:12 AM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
Re: IAC valve
415 is TPI. If you look it up for a 350 vin 8 its also 415. Both 305 and 350 TPI IACs are the same.
92firebirdguy
Sep 1, 2016 07:53 AM
sandman92084
Sep 12, 2015 10:27 PM
earlpote
Sep 12, 2015 11:55 AM
greenyone
Sep 8, 2015 08:41 PM
greenyone
Sep 2, 2015 03:39 PM
