Need an oil cooler seal. Impossible to find part.
Old Nov 5, 2012 | 03:22 PM
blackbeauty89's Avatar
Car: 1989 Pontiac GTA/2007 TrailblazerSS
Engine: 350 L98/LS2
Transmission: 700-R4/4L70E
Axle/Gears: 3.27/4.10
Oil cooler seal **** out and pissed oil everywhere. But it seems like no parts stores even know what you're talking about when you search the part.
They can find a oil cooler but its only an aftermarket application. There's no OE part for it
Anyone have an idea on where I can find this? I'd like to keep it factory unless I absolutly have to take another route
Old Nov 5, 2012 | 03:33 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Need an oil cooler seal. Impossible to find part.
Old Nov 5, 2012 | 03:41 PM
Engine: Lb9
Transmission: M20
you might want too see if felpro es72671 will work.
Old Nov 5, 2012 | 04:58 PM
Twin_Turbo's Avatar
It's just a regular oil filter seal, however if you get some make sure you get a pretty tall one or it will not seal. It sits in a recess in the cooler and needs to stick out a fair amount to be able to compress. If it doesn't compress enough and the flange hits the block you will have a leak.
toronto formula
Nov 10, 2015 06:17 AM
Navy8125
Aug 21, 2015 09:32 AM
Dialed_In
Aug 20, 2015 01:45 PM
Street Lethal
Aug 12, 2015 11:33 AM
