Gas leak help?
Old Nov 17, 2012 | 10:34 AM
SpeeProd's Avatar
Gas leak help?
Hey guys,
I have a 1987 IROC z-28, with the 305 TPI automatic transmission. The other day, i was driving home, and I noticed my car was kinda driving a little weird... so I pulled off to the side of the road, and as soon as i let off the gas, the car stopped. I looked at the engine and didn't see anything out of the ordinary, but after trying to start it a few times, I smelled gasoline. Found out that it's leaking out of the throttle body where the intake is attached. It seems as though there is a lot of gas just kind of slowly leaking out.. but when i press the gas, it opens the throttle and gas pours out.
Have any of y'all had a similar problem? If so, how did you fix it?
Old Nov 17, 2012 | 09:58 PM
watajob's Avatar
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Re: Gas leak help?
I'd guess the diaphragm in your FPR is shot.
Old Nov 18, 2012 | 01:09 PM
SpeeProd's Avatar
Re: Gas leak help?
Where and what is the FPR?
Old Nov 18, 2012 | 02:22 PM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
Re: Gas leak help?
It sits under the TPI plenum. It has a vacuum hose going to it and has a circle of torx head screws holding it together. Pull the vacuum hose off and see if there is fuel in it. If there is, then the diaphragm is leaking.
Old Nov 26, 2012 | 06:01 PM
SpeeProd's Avatar
Re: Gas leak help?
Okay so i checked the FPR, there was one rubber tube coming out of it and it was dry. I opened up the throttle and there is a good amount of gas still sitting in there. Any ideas of what i could do?... I've never had a problem like this. I dont want to take it to a shop.. id much rather do it myself. Any suggestions would be greatly appreciated!
Thanks,
Spencer
Old Nov 28, 2012 | 03:04 AM
watajob's Avatar
Car: 92 T/A 'vert
Re: Gas leak help?
Try KOEO and I'll bet you see gas coming out of where the hose connects to the FPR.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
dbrochard
Oct 3, 2015 12:43 PM
TBRays98
Sep 6, 2015 05:05 PM
tgp1990
Sep 4, 2015 06:24 AM
