running extremely rich
Old Nov 22, 2012 | 09:42 PM
wilson91z28's Avatar
Car: 1991 chevrolet camaro z28
Engine: 5.0 TPI
so is there a way i can adjust the fuel mixture???? or is it just controlled by the ecm? my 91 tpi is running extremely rich. i think it could be the reason it is causing it to run rough at high rpms? i really dont want to look dumb and take it to a shop when i can do it myself. any suggestions...also i have replaced my distributor would that have anything to do with it if its not running right?
Old Nov 23, 2012 | 10:02 AM
lonestar7's Avatar
Car: 1988 Firbird formula 350
Engine: 5.7L TPI
Axle/Gears: 3.27 Nine Bolt
Re: running extremely rich
It could be a number of things. I would do a search here on "running rich" and "checking injectors" and read whats been posted. I would suspect you may have a leaky injector(s) or maybe a leaky fuel pressure regulator. Are you getting an SES light, throwing any error codes?
Old Nov 23, 2012 | 11:51 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
How do you know it's running rich? You smell gas? Check your timing first!
Old Nov 24, 2012 | 08:31 AM
GTA1990's Avatar
Car: 1991 Trans Am
Engine: L31, LT4 hot cam
Axle/Gears: 3:42 LSD
know much about the service history on the car? As O2/ lambda sensors are so cheap, I normally change these out as routine on buying a used car and have always noticed an improvement in running/ mpg.
also as above, check the injectors by pulling out a mulit-meter and checking the ohms of each injector. I forget the tolerences but do a search and you should easily find it. I have one low ohm injector and that is causing a rich condition (as verified on the dyno) and drivability issues
Old Dec 13, 2012 | 02:01 PM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
CTS may be causing you problems... itself or wiring...
Old Jan 7, 2013 | 06:47 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
I would definitely start by testing the CTS. It should read about 3,400ohms at 70 degrees(cold engine), and 180 ohms at 220 degrees (hot engine). Also, pull the hose off of the fuel pressure regulator and look for fuel in the hose, coming from a ruptured regulator diaphram.
One tool that I find pretty much indispensable when diagnosing any EFI car is a compatible scan tool. The scan tool lets me see data from each sensor as the ECM sees it. This can save alot of time chasing down a sensor issue. As we develop more diagnostic experience, information from the scan tool can also help us find many issues aside from faulty sensors.
Old Jan 7, 2013 | 08:12 PM
southbay08's Avatar
If you do decide to check the resistance on your injectors be sure to do it
when the injectors are warm and cold.
A quick way to check for leaky injectors....run the engine for a minute or two, then pull the plugs. If you have wet cylinders you have leaky injectors.
eightsixseven
Dec 16, 2024 01:50 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
tmellott89
Aug 16, 2015 02:58 PM
squiggy2
Aug 9, 2015 09:30 PM
