LB9 Or L98?
Old Dec 11, 2012 | 05:24 AM
armybyrd's Avatar
Car: '02 T/A
Transmission: 4l60e
LB9 Or L98?
Im looking at a car thats got a TPI engine swapped in. Is there a way to tell which one it is besides obviously running the engine block numbers?
Old Dec 11, 2012 | 06:31 AM
Re: LB9 Or L98?
Sure.
Run the block numbers.
If that doesn't work, then run the block numbers, instead.
The one to use is the casting number, conveniently located out in the open in plain sight, on top of the bell housing flange behind the driver's side head. Don't bother with the "stamping" codes on the deck on the pass side, too hard to get reliable and complete data on those.
Old Dec 12, 2012 | 09:01 AM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Re: LB9 Or L98?
Measuring bore and or stroke?
AS you can see, the block numbers is the only way to know for sure.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
91chevyz28
Feb 10, 2022 07:58 PM
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
FormulasOnly
Jul 23, 2018 08:47 AM
Tarizza
Sep 24, 2015 12:57 PM
