knocking tapping noise
Old Dec 20, 2012 | 10:56 AM
karl's-92'-z28's Avatar
Car: Too many cars
Ok I have a problem with my daily driver. Its a 91 350 TPI Formula with 76,000 original miles. Their is a kocking tapping sound that happens when climbing a hill or when I put a load on the engine. She also hesitates like she bogging down & I loose power. I have kinda ease the pedal, its like its gasping for air. Any help would be greatly appreciated.
Thankyou,
Karl
Old Dec 20, 2012 | 11:21 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: knocking tapping noise
Have you checked your base timing with the est disconnected engine warm? Sounds like you are describing pre detonation.
Old Dec 20, 2012 | 11:30 AM
IROCZ1989's Avatar
Car: 1989 IrocZ
Engine: 421 Dart Stroker
Transmission: 4L60E Cahall Performance Built
Axle/Gears: Midwest Chassis Fab 9/ 3.55 gears
Pinging comes to mind. Check plug wires and cap for cracks. Easier at night to see if the wires are sparking off metal in the engine. Also check the electrodes on the plugs, i dont run platniums for this reason, they like to pre detonate on crap gas, which is out ther this time of year. Have you installed hotter plugs recently? Electrodes after pre ignition like to melt so check this as well. But first and formost easiest thing to check is base timing without getting to much into anything. Hope this helps.
Old Dec 20, 2012 | 12:25 PM
Car: Too many cars
Est?
Old Dec 20, 2012 | 12:27 PM
Car: Too many cars
She is due for a tune up...so everything will be replaced & timing checked. Could it be anything else also that would cause her to loose power & bog down. If I feather the pedal shes ok up hills...
Old Dec 20, 2012 | 12:32 PM
Engine: Lb9
Transmission: M20
Originally Posted by karl's-92'-z28
Est?
Est=Electronic Spark Timing
Old Dec 20, 2012 | 12:33 PM
Engine: Lb9
Transmission: M20
A restrictive exhaust low fuel pressure can all have a effect of reduced power under a heavy engine load.
Old Dec 20, 2012 | 01:13 PM
Jeffs82TA's Avatar
disconnect the est wire and see if the problem goes away
Old Dec 20, 2012 | 01:18 PM
Engine: Lb9
Transmission: M20
drive it around with base timing !
Old Dec 20, 2012 | 01:19 PM
Car: Too many cars
I replaced the fuel pump like a year ago. I have a complete exhaust system for her, just waiting for the cat back to come in. Im going to delete the air pump & air tubes. If it runs better with the EST disconnected, just leave it?
Old Dec 20, 2012 | 01:22 PM
Jeffs82TA's Avatar
I never said that. I had this same issue with my 1990 vette would rattle like heck and sometimes not want to start. Never found the problem as it came and went but disconnecting the est wire always made the car run better till it decided to get the fart out of it's system.
I kinda think it is the integral est module found in the 7727 and 7730 ecm.
RedLeader289
May 28, 2019 01:47 PM
bigjay89gta
Oct 15, 2015 08:04 AM
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
sjorgens
Oct 1, 2015 07:54 PM
efiguy
Sep 27, 2015 01:30 PM
