Fuel Pump Problem Again?
Old Dec 23, 2012 | 11:51 PM
barristerjim's Avatar
Car: 87 IROC-Z
Engine: 305 TPI (LB9)
Hi Guys, I have my car stored in an unheated garage for the Winter. I have a trickle charger on the battery and Sta-Bil and Strartron in the gas tank. I've been starting it up about once a month and she always had started immediately and idles fine with no problems whatsoever. Well, Saturday I started her up and she ran just fine for 10-15 minutes, but then just completely shut down, and just barely began to run for a few seconds when I turned the ignition over again and that was it. I had the orginal fuel pump replaced by a reputable garage in October 2009, and I noticed that now when I turn the key on I dont hear the fuel pump hum for a couple seconds as I always had. Do you guys think I have another fuel pump issue or is there anything else I should check? All fuses were fine. I went back to the garage that replaced the pump and the service manager said he found it hard to believe I could have a fuel pump go bad so soon with so few miles on the car, and that while it was out of warranty they would "work with me" but if it did turn out to be the fuel pump it would likely be $500. So needless to say any suggestions you could provide would be greatly appreciated.
Old Dec 24, 2012 | 12:46 AM
ahankins32984's Avatar
Car: 1986 Camaro Z28
Engine: 5.0 305 TPI
Axle/Gears: posi 3.73
Re: Fuel Pump Problem Again?
it could be a filter clogged as well but as for the pump it is quite possible for the pump to go bad mine was replaced in April of last year and July of last year had to be replaced again due to the pump becoming clogged so I would definitely check into the pump possibly being clogged as well but it definitely sounds like its a fuel related issue
Old Dec 24, 2012 | 10:35 AM
Car: 87 IROC-Z
Thanks for your input and happy holidays. Had it happened a month earlier, a new fuel pump would have quite possibly been on my Christmas list, but you'll have that.
Old Dec 24, 2012 | 12:59 PM
Car: 87 IROC-Z
Thanks to everyone who answers my posts and all of you guys who post on so many different topics when I don't post the question and don't have the knowledge to contribute a response to, but learn so much from. It truly is appreciated. Happy Holidays to all you guys and everyone at ThirdGen.
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Grant2k
Jul 10, 2018 04:01 PM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
