TPI makeover: WARNING Pic heavy!!
Old Jan 15, 2013 | 12:51 PM
  #51
dabomb6608's Avatar
Car: 86 Trans Am/85 K5 Jimmy
Engine: 406 FIRST/350 TPI
Transmission: TKO 600/700R4
Axle/Gears: 9Bolt/10Bolt front & back
Re: TPI makeover: WARNING Pic heavy!!
That spot is where my factory air intake was on my 85. It was on the passenger side.
Old Jan 15, 2013 | 01:18 PM
  #52
TPI_BLAZER's Avatar
Car: 1986 K5 Blazer
Engine: 1992 5.7L TPI
Yea, thats what Ive been told. Ive got one on both sides, pulled the plugs, should allow some extra air in the engine......
Old Jan 15, 2013 | 01:48 PM
  #53
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Just need to get an electric fan on there, that will make things a lot easier!
Old Jan 15, 2013 | 03:07 PM
  #54
tpi84stepside's Avatar
They are there to keep water from going directly into your air intake on the original setup. I plumbed my K&N to a spot directly in front of one on the driver side.
Old Jan 15, 2013 | 07:43 PM
  #55
TPI_BLAZER's Avatar
Car: 1986 K5 Blazer
I'll find out tomorrow but I think a 52mm TB just fell into my lap.
Would there be any benefit of putting this on...he mentioned something about adjusting the TPS to .75v...?
Old Jan 15, 2013 | 07:48 PM
  #56
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
The correct tps the 90-92 tpi does not have elongated screw holes and is non adjustable if you install a 85-89 tpi tps you would want to adjust you min idle speed first with the iac in and the set the tps from 0.660VDC to 0.760VDC this would be measured with the throttle blades closed engine off on the blue feedback wire to the ecm and ground.
Old Jan 15, 2013 | 07:52 PM
  #57
TPI_BLAZER's Avatar
Car: 1986 K5 Blazer
Yea, not sure it its 85-89 or 90-92 yet.
Old Jan 16, 2013 | 03:12 PM
  #58
TPI_BLAZER's Avatar
Car: 1986 K5 Blazer
Went to change the fuel filter today and realized they had a 82'-84' Vette filter...instead of the Z28 filter I bought ....
Fuel pressure regulator diaphram showed up:
Ill be getting that on tomorrow and work towards getting the plenum back on.
Old Jan 16, 2013 | 03:19 PM
  #59
TPI_BLAZER's Avatar
Car: 1986 K5 Blazer
Now to the TB.....
Guy at work literaly gave me a Summit billet 52mm TB. Ill have to use my lower housing and IAC, as well as switch the linkage.
1) Is switching the linkage jus as easy as that?
2) The IAC is just about the only sensor that wasnt going to get replaced, should I?
3) I have a new TPS, looks like that will mount right up...any adjustments?
4) Coolant bypass...???
Old Jan 16, 2013 | 05:54 PM
  #60
Engine: Lb9
Transmission: M20
You will need a throttle cable for 85-88 tpi . I think this is a professional products throttle you should contact them to see if the have the 89-92 lever. You should clean your iac pintle tip and adjust the minimum air / idle speed. You need to look at the back of the throttle body and see if both bores are connected bye the iac passage other wise you need to notch this section so the iac can get manifold vacuum. Let me know if you need a picture of this.
http://www.autozone.com/autozone/par...ier=59535_0_0_
Old Jan 16, 2013 | 05:59 PM
  #61
TPI_BLAZER's Avatar
Car: 1986 K5 Blazer
So I cant just swap the levers that hold the cables?
Both bore are accessable to the IAC.
Old Jan 16, 2013 | 06:14 PM
  #62
Engine: Lb9
Transmission: M20
professional products 69705 shows for 85-92 it should have originally came with a install kit with two throttle arm levers. If you buddy dosn't have it You should email or call professional products.
Old Jan 16, 2013 | 06:23 PM
  #63
TPI_BLAZER's Avatar
Car: 1986 K5 Blazer
Friend doesnt have it, I just cant take the linkage off the 48mm and put it on the 52mm, at work right now and cant see how they mount any differently? If not forget it Im not gonna waste my time with it.
Old Jan 16, 2013 | 06:28 PM
  #64
Engine: Lb9
Transmission: M20
The stock one is peened over the d shape on the shaft maybe different and the spring may not work with a oem lever. If you don't want it i'll work a trade lol.
Old Jan 16, 2013 | 08:29 PM
  #65
Engine: Lb9
Transmission: M20
If you do convert the saginaw gm hard fuel line to a/n you can use Fragola 491970 and 491971 or earls 9894DBJERL and EAR-9894DBHERL
Old Jan 16, 2013 | 09:04 PM
  #66
TPI_BLAZER's Avatar
Car: 1986 K5 Blazer
Not really tracking... The lines that were there were cut at one and and shoved into the rubber lines, held on with band clamps. These lines are threaded at both ends??
Do the rubber lines need fittings in them?
At the rail they bolted like they are supposed to.
Old Jan 16, 2013 | 09:08 PM
  #67
Engine: Lb9
Transmission: M20
sorry, I thought you posted asking jason for the hardline. The Stock ones are saginaw o-ring on both sides so you would need to convert to an -6 and build new flex lines.
Old Jan 17, 2013 | 08:50 AM
  #68
TPI_BLAZER's Avatar
Car: 1986 K5 Blazer
This is what I was asking about, hopefully we're on the same page, just sent PayPal.
Want to run new rubber lines off those to the hard lines in the fram rail. Trying to find the right female-male hose barb adapter for the ends of the lines....
http://www.summitracing.com/parts/aer-fbm1512
http://www.summitracing.com/parts/aer-fcv0620
Old Jan 17, 2013 | 08:59 AM
  #69
Engine: Lb9
Transmission: M20
If the lines on the frame rail are metal You should flare them at 37 and instal a 3/8 and 5/16 a/n tube nuts. Then Built a a/n flex line to connect the two.
Old Jan 17, 2013 | 09:13 AM
  #70
Engine: Lb9
Transmission: M20
or were you talking about converting the saginaw o-ring fitting to a barb ? with
Fragola 491970 and 491971, 484106 and 496106 .
Old Jan 17, 2013 | 09:21 AM
  #71
TPI_BLAZER's Avatar
Car: 1986 K5 Blazer
Looking for the fitting to adapt these to -an flex and flare the rail lines like you said.
Old Jan 17, 2013 | 09:37 AM
  #72
Engine: Lb9
Transmission: M20
Fragola 491970 and 491971 or earls 9894DBJERL and EAR-9894DBHERL and build a flex line to go over to the frame rail with female ends on the flex line.
here is a picture I found on the net the top blue fitting is a earls converting the saginaw o-ring to an -6. If you get tube nuts don't forget to order the sleeves.
Old Jan 20, 2013 | 05:48 PM
  #73
TPI_BLAZER's Avatar
Car: 1986 K5 Blazer
Realized yesterday that I had my runners on backwards, wasnt very happy about that!
Got them back on today, along with dizzy cap - rotor - coil - wires - plugs (#6 was a beeyotch!) - MAP - new EGR vac lines - new PCV lines - IAT and plemun:
Working on this thing is like peeling an onion. Every where I turn theres something.....
.......any good ideas to make this better?
Old Jan 20, 2013 | 10:16 PM
  #74
Engine: Lb9
Transmission: M20
Were does That wire go to off the junction block ? With the melted junction block terminal there was a excessive draw on this circuit or bad connection causing too much resistance or a short on this wire.
Old Jan 21, 2013 | 09:50 AM
  #75
TPI_BLAZER's Avatar
Car: 1986 K5 Blazer
Havent traced it back that far yet. I knew it needed to be replaced, just been putting it off. Im gonna add a multi slot box so I can run some extra lighting off of it later.
In the meantime:
Old Jan 21, 2013 | 09:53 AM
  #76
Engine: Lb9
Transmission: M20
Old Jan 22, 2013 | 01:00 PM
  #77
TPI_BLAZER's Avatar
Car: 1986 K5 Blazer
Had a few hours this morning....took the ECM out to pull the memcal:
...and cut the ears off the IAC housing:
...Ill be sealing the ends up, probably tomorrow.
Old Jan 22, 2013 | 01:18 PM
  #78
Engine: Lb9
Transmission: M20
expansion plugs or pipe plugs give a decent look or you can cut it down further.
you wern't kidding they barried that ecm
Old Jan 22, 2013 | 02:25 PM
  #79
TPI_BLAZER's Avatar
Car: 1986 K5 Blazer
Bam...
Now my cheesy fix for the upper rad hose. Scroll up and remember what I had on there...
Using an OE 92' Camaro upper, cut slightly, with coupler, just need to add a section of straight hose, with my U-bolt hose keeper. Also using a water neck from 96'-98' Chevy 1/2T:
Also got my new junction box ordered...actually got two, hope to try something out...
Old Jan 22, 2013 | 07:34 PM
  #80
TPI_BLAZER's Avatar
Car: 1986 K5 Blazer
Originally Posted by TPI_BLAZER
Only gonna need 12" of hose....rather than buy a hole hose and cut it down...Im thinking this stuff should hold up... http://www.oreillyauto.com/site/c/de...&keyword=28445
Old Jan 22, 2013 | 07:41 PM
  #81
Engine: Lb9
Transmission: M20
looking good
Old Jan 23, 2013 | 12:21 PM
  #82
TPI_BLAZER's Avatar
Car: 1986 K5 Blazer
Old upper v New upper:
Also installed bypass hose: Dayco 87658
Had a few minutes to spare:
Old Jan 24, 2013 | 01:12 PM
  #83
TPI_BLAZER's Avatar
Car: 1986 K5 Blazer
Todays project was going to be: replace the crappy fuel lines the PO used. The hand bent lines were what was used to go from the rubber lines to the fuel rail. Add to it, those rubber lines were toast. I couldnt come up with a set of OE hard lines to run under the alt to the rubber (which I was going to replace with new rubber) so I decided to do SS all the way to the lines in the frame rail.....with the expectation of someday going as far back as possible to the tank.
PO's handy work:
So I ordered this up:
Not having much experience in this area apparently I ordered SS P.T.F.E lines and the fittlings I odered wont work with them? Im having a hell of a time getting them to lock the hose down..... do I need to re-order SS rubber lines?
Old Jan 24, 2013 | 02:17 PM
  #84
TPI_BLAZER's Avatar
Car: 1986 K5 Blazer
My Trick-Flow knock off came in today as well. As if my day wasnt already going to crap I mounted it up and it doesnt look like its going to work. I tried mounting it both ways and there just isnt enough clearance either way:
And to top it off, the upper rad hose it pieced up is going to need to be re-done....the air filter wont fit with it routed that way.
Old Jan 24, 2013 | 02:27 PM
  #85
Engine: Lb9
Transmission: M20
Fragola catalog page 28 lists the fittings to go with this hose.
Old Jan 24, 2013 | 03:12 PM
  #86
TPI_BLAZER's Avatar
Car: 1986 K5 Blazer
EDIT: located the right PFTE fittings....
Old Jan 24, 2013 | 10:31 PM
  #87
Engine: Lb9
Transmission: M20
just curious on the trick-flow elbow what is in the way running it towards the passenger side and extending odd it with a 3" cai kit.
Old Jan 24, 2013 | 10:33 PM
  #88
TPI_BLAZER's Avatar
Car: 1986 K5 Blazer
Hits the alt bracket...before the TB can get squared up to mount.
Old Jan 24, 2013 | 10:38 PM
  #89
Engine: Lb9
Transmission: M20
now I see it that sucks over a inch off.
Old Jan 25, 2013 | 02:57 AM
  #90
TPI_BLAZER's Avatar
Car: 1986 K5 Blazer
I could cut it back, but I'm not sure there would be enough left for a boot to hold on too.
Old Jan 25, 2013 | 12:44 PM
  #91
TPI_BLAZER's Avatar
Car: 1986 K5 Blazer
Got the new fittings in this AM. Was a PITA getting them hooked up to the fuel rail, but once I did I realized I couldnt route them the same way as OE. As you can see its pretty tight in there:
Being as the lines are SS I said why hide them? So I routed them like this:
Just have zip-ties on them until I can find something classy'ier. Best part about it is that I have enough line to go all the way back to the fuel filter - minimizing the connections inbetween. Starting to look like a motor again:
52mm TB on the way, new junction box due any day, bolt in T'stat, upper-lower hoses, ECM programmed, hook the battery up and start this pig!
Old Jan 25, 2013 | 01:09 PM
  #92
Car: 1971 Camaro
Engine: 427
Your fuel lines are taking the scienic route
Old Jan 25, 2013 | 01:11 PM
  #93
Engine: Lb9
Transmission: M20
Old Jan 25, 2013 | 01:19 PM
  #94
Engine: Lb9
Transmission: M20
The only thing I can think that you can improve on the air filter is do some bends like this but towards the passenger side ending up by the rad support inlet and a open element the serp tensioner is in the way a but maybe with a tight 90 silicone elbow yo might be able to do it. I have a rubber lt1 bellows your welcome to have I can send to you and make measurement off of it if you want.
Old Jan 25, 2013 | 01:25 PM
  #95
TPI_BLAZER's Avatar
Car: 1986 K5 Blazer
Yea, I dont mind making my own cai, its just clearing that first 120* or so bend. If I can get it behind the alt, Ill be golden.
Ultimately I think the best plan id to go to dual electric fans and just run it in front of the alt...that shroud is killing me.
Old Jan 25, 2013 | 01:29 PM
  #96
Engine: Lb9
Transmission: M20
I do have some new electric fans I would let go for fairly cheap left over from a buick 350 I put in a chevy luv. I will have to see what the overall size they are and cfm if you are interested.
Old Jan 25, 2013 | 01:34 PM
  #97
Car: 1971 Camaro
Engine: 427
Yeah, electric fan is the way too go.
Old Jan 25, 2013 | 02:42 PM
  #98
TPI_BLAZER's Avatar
Car: 1986 K5 Blazer
If I go dual elect, I going all in and getting a Griffin combo: new rad w/dual fans....
Better start saving some cheddar'....
Old Jan 25, 2013 | 02:48 PM
  #99
Car: 1971 Camaro
Engine: 427
You can go cheap.
Like I said before,
My 1969 c10 with a warmed over 350, I ran an ebay replacement all aluminum radiaor, $200
A 16" fan from abad71camaro on ebay $40
Thermostat Switch on at 200 off at 185 from abad71camaro on ebay $40
Kept it cool.
Swapping the same setup to my 1971 camaro.
If your current radiator is good, you can just ad the fan and switch. I am sure it will keep up.
In Fact, on my 55 belair, which has an 11:1 427 BBC I ran a Stock 1955 V8 Radiator with the same fan and a on at 180 off at 160 switch and it kept it cool! Even with 4.71 rear gears. I run a CSR electric water pump on it.
Old Jan 25, 2013 | 02:57 PM
  #100
Engine: Lb9
Transmission: M20
drool , drool
