TPI makeover: WARNING Pic heavy!!
Old Feb 24, 2013 | 10:29 PM
  #201
TPI_BLAZER's Avatar
Car: 1986 K5 Blazer
Engine: 1992 5.7L TPI
Re: TPI makeover: WARNING Pic heavy!!
Originally Posted by tunedperformanc
If you want the part number for a pigtail that would plug into that let me know and I will see if I can provide it for you.
Yea, Ill take that pn. So basically, just hook up power to the tach and use the pig tail to connect to the gray connector and done...?
Old Feb 24, 2013 | 10:47 PM
  #202
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
yes you just need power and ground to the tach and the white wire feed is the tach signal. if you want the gauge to iluminate you will need to check for power on your headlight switch one terminal will go to the gauges and will have power in the parking light mode and the headlight position. The tach pigtail is a female spade and looks to me like its a acdelco pt486 or gm 12117353.
Old Feb 24, 2013 | 11:12 PM
  #203
TPI_BLAZER's Avatar
Car: 1986 K5 Blazer
Thx again...
Old Feb 24, 2013 | 11:37 PM
  #204
Engine: Lb9
Transmission: M20
No problem
Old Feb 27, 2013 | 11:44 AM
  #205
TPI_BLAZER's Avatar
Car: 1986 K5 Blazer
This should please the neighbors.... and hopefully the AZDEQ:
Old Feb 27, 2013 | 01:51 PM
  #206
Engine: Lb9
Transmission: M20
I have never heard the 44 , but have had 40 single and dual chamber and love that raspy sound
Old Feb 27, 2013 | 02:54 PM
  #207
TPI_BLAZER's Avatar
Car: 1986 K5 Blazer
44 looks like it falls in between the 40 and the 10.... hope to have it on tomorrow
http://www.flowmastermufflers.com/?page_id=11098
Old Feb 27, 2013 | 02:59 PM
  #208
Engine: Lb9
Transmission: M20
should have a nice sound, can't wait to see the numbers from the new test. Fingers are crossed
Old Feb 28, 2013 | 12:53 PM
  #209
TPI_BLAZER's Avatar
Car: 1986 K5 Blazer
This is a Catco Cat and FM Super 44 off a Y pipe and Doug Thorley headers, 3" all the way out from collector...
Overall very happy. My impressions on the 44 is that is it deeper and raspier than the Magnaflow that was on it (model unknown, 3" I/O about 28" long). I think it is actually quieter at idle-OD too...
Had some time to kill before work...
Might have to re-think that antenna mount, lol...
Old Feb 28, 2013 | 12:54 PM
  #210
TPI_BLAZER's Avatar
Car: 1986 K5 Blazer
Freeway onramp....
  #211
TPI_BLAZER's Avatar
Car: 1986 K5 Blazer
Again, pretty happy with the results. I wanted a simple turn down out of the muffler, but I talked to the guys at the AZ MVD and they pretty much said the wouldnt test a vehicle if they had to reach very far inside the fender well.
Next option was to have a pipe made just for testing...nah too much work, decided to kick it out in front of the rear tire.
Truck isnt a rock crawler and Im happy with the suspension height so Im not worried about it effecting ground clearance on a trail...
True test will be Sat..!!!
Old Feb 28, 2013 | 05:59 PM
  #212
Engine: Lb9
Transmission: M20
looking good
Old Feb 28, 2013 | 06:15 PM
  #213
Zane M's Avatar
Car: 1991 GTA
Engine: LB9
Looks great.
Old Feb 28, 2013 | 06:18 PM
  #214
TPI_BLAZER's Avatar
Car: 1986 K5 Blazer
Thx...
Old Feb 28, 2013 | 06:38 PM
  #215
Engine: Lb9
Transmission: M20
great sound
Old Mar 1, 2013 | 09:19 AM
  #216
TPI_BLAZER's Avatar
Car: 1986 K5 Blazer
So Im up this morning ready to take it for emissions test.....wont start...wtf?
Ran great all day yesterday...motor turns over easily, I noticed there is no pressure on the fpg...been trying for 10 min to start it.
Should that thing hold pressure over night or at least build pressure when Im trying to start it? At zero tells me its not starting because its not getting fuel...yes tank has gas, at 1/2.
Old Mar 1, 2013 | 09:25 AM
  #217
Engine: Lb9
Transmission: M20
I cant believe your luck. The fuel pressure does bleed off back to the tank within 30 mins. When you turn the key to the accessory position the 2 second fuel pump prime will build the pressure to the fuel rail. Can you hear the pump kicking on ?
Old Mar 1, 2013 | 09:29 AM
  #218
TPI_BLAZER's Avatar
Car: 1986 K5 Blazer
Nope...kinda figured that what it was. Knew I should've changed it when I had the tank down.
Old Mar 1, 2013 | 09:34 AM
  #219
tpi84stepside's Avatar
Ouch...
Maybe it's just the relay..Or fuse.
Don't they (pumps) usually get weak before they go??
Old Mar 1, 2013 | 09:35 AM
  #220
TPI_BLAZER's Avatar
Car: 1986 K5 Blazer
Originally Posted by tpi84stepside
Ouch...
Don't they usually get weak before they go??
I have been having the hard start issues though...so maybe it was on the way out.
Old Mar 1, 2013 | 09:42 AM
  #221
I can hear my relays click when I turn the key on..How about you? are they somwhere that you can hear them?
Old Mar 1, 2013 | 09:43 AM
  #222
TPI_BLAZER's Avatar
Car: 1986 K5 Blazer
...are they somwhere that you can hear them?
No, I dont hear anything.
Truck was a carb'd 305, mech pump, before the swap so Im neven sure where to start looking for them.
Old Mar 1, 2013 | 09:49 AM
  #223
TPI_BLAZER's Avatar
Car: 1986 K5 Blazer
Right....
Cant say that I heard a click...Ill start here.
Old Mar 1, 2013 | 09:51 AM
  #224
My truck interior looks like yours..I put the computer and the relays under the dash near where the old computer was..I guess yours could be anywhere...PITA
Old Mar 1, 2013 | 09:54 AM
  #225
Engine: Lb9
Transmission: M20
It looks like the relay under the hood on the bulk head passenger side is the fuel pump relay and fuel pump fuse right next to it. You should check the fuse first the you can even look at your aldl connector if it has a wire in pin g that goes to the relay so you could apply power there to see if the pump kicks on. Bypassing the low oil shut down switch with a paper clip from the orange wire to the grey wire will give power directly to the pump as well. The orange wire is hot all the time but is fused.
Old Mar 1, 2013 | 09:55 AM
  #226
Engine: Lb9
Transmission: M20
Right....
Right
Old Mar 1, 2013 | 09:57 AM
  #227
TPI_BLAZER's Avatar
Car: 1986 K5 Blazer
You should check the fuse first...
Fuse is good, just to check its a 30a in there.
Gonna run to O'reilly's for a relay real quick, they are literaly 1mi away
Old Mar 1, 2013 | 10:00 AM
  #228
Engine: Lb9
Transmission: M20
I think you should rename the thread , tpi blazer more than I ever wanted to know about tpi and my blazer.
Old Mar 1, 2013 | 10:01 AM
  #229
Engine: Lb9
Transmission: M20
http://www.hotrodlane.cc/newtech/tun...elcircuit.html
Old Mar 1, 2013 | 10:29 AM
  #230
TPI_BLAZER's Avatar
Car: 1986 K5 Blazer
No sheet right...
New replay, system pressurized right away....started right away....THX!!!
Off to emissions
Old Mar 1, 2013 | 10:30 AM
  #231
TPI_BLAZER's Avatar
Car: 1986 K5 Blazer
Old Mar 1, 2013 | 12:12 PM
  #232
TPI_BLAZER's Avatar
Car: 1986 K5 Blazer
12/14/12:
HC: 6.25 Standard: 4.0 FAIL
CO: 101 Standard: 40 PASS
NOX: 4.4 Standard: 5.5 FAIL
02/12/13:
HC: 6.15 Standard: 4.0 FAIL
CO: 27.3 Standard: 40 PASS
NOX: 6.35 Standard: 5.5 FAIL
03/01/13
HC: 4.03 Standard 4.0 FAIL by .03!!!!
CO: 22 Standard: 40 PASS
NOX: 5.8 Standard: 5.5 FAIL by .81!!!
Im at a loss., I even put a qt of Denatured Alcohol in the tank... may just need to put AIR system back on..??
Pass equip insptection 3X without it....
Old Mar 1, 2013 | 12:33 PM
  #233
86T/A_Ram_Air's Avatar
Car: 91 Trans Am
Engine: 355 TPI
Transmission: Built T-5
whats your base timing at?
Old Mar 1, 2013 | 12:36 PM
  #234
TPI_BLAZER's Avatar
Car: 1986 K5 Blazer
Just set it to 6-7* last week...
Old Mar 1, 2013 | 12:42 PM
  #235
Car: 91 Trans Am
Engine: 355 TPI
the only thing I can think of other than that is that the A/F ratio is off but I doubt it. It should be passing. Did you retain EGR?
Old Mar 1, 2013 | 12:49 PM
  #236
TPI_BLAZER's Avatar
Car: 1986 K5 Blazer
Originally Posted by 86T/A_Ram_Air
Did you retain EGR?
Yes, was the only part I didnt replace with new.....
Old Mar 1, 2013 | 01:08 PM
  #237
Engine: Lb9
Transmission: M20
The high nox maybe the egr. If you do decide to put the air pump back on I will return some funds and take care of the programing.
Old Mar 1, 2013 | 01:34 PM
  #238
TPI_BLAZER's Avatar
Car: 1986 K5 Blazer
OK, gonna pull the plenum...again...and replace EGR. Its the only thing that wasnt replaced...
Double check timing.
Check plugs.
Maybe change oil just for the hell of it...did it 1 month ago.
Pull O2 and look at that...
Change evap filter..
Try again, more concentrated solution of alcohol. If fail, then put AIR back on.
Here pic of Evap..pretty much was left alone, anything look out of place. I know there is supposed to be a solenoid there???
Old Mar 1, 2013 | 02:59 PM
  #239
TPI_BLAZER's Avatar
Car: 1986 K5 Blazer
Pulled the canister, is that even possible? Could'nt figure how to open it...RA sell a filter...so...?
Old Mar 1, 2013 | 03:55 PM
  #240
TPI_BLAZER's Avatar
Car: 1986 K5 Blazer
It appears I have the wrong canister for 92' TPI, see above. Correct for 92' TPI is:
Correct for 86' Blazer is:
Im not even sure what I have, appears to be late 70's GM truck...
Old Mar 1, 2013 | 11:18 PM
  #241
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
I think it highly unlikely that your CCP system would have anything at all to do with your emissions numbers.
If you have a functioning EGR system, then do not add Ethanol to your fuel.
In fact you are likely to test better using 87 octane, E0 if possible.
I would check your AFR to be sure, but assuming your AFR is correct, then it seems possible your EGR passages may be at least partially blocked by either a gasket or carbon build-up. I would check into that while you have the plenum off.
More spark advance increases burn efficiency, and so raises the NOX content of the exhaust. EGR counter-acts this by reducing burn efficiency.
The ECM normally adds some spark advance during the time it is assuming that EGR is flowing. If you have restricted EGR flow, but are getting the advance, then it will negatively affect your emissions numbers.
Misfires can cause higher HC in the exhaust. Sometimes tightening up the spark-plug gaps to 0.030" can help, but misfires generally indicate another problem as the cause.
Old Mar 1, 2013 | 11:34 PM
  #242
TPI_BLAZER's Avatar
Car: 1986 K5 Blazer
If you look at my canister its not even the right one. Basically the gas tank vents into it and gets sucked right back up into the TB. There's no purge valve or vent to control the flow which in turn does effect the A/F. It may not be the specific reason I failed, but I believe it contributed a little...and if you look at my numbers I failed by just a little. Gonna replace the canister with the correct unit and hose routing.
As far as the EGR its just gonna get replaced. I should've done it while the plenum was off...I have no idea how old or what shape its in. If I have to go through the trouble of getting to it to inspect it, Ill just replace it for piece of mind.
Thx for the tip on the alcohol and 87. Will double check timing this weekend, but set it as close to 6* as I could last weekend.
Old Mar 2, 2013 | 12:02 AM
  #243
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
If your CCP is affecting your AFR then your BLMs at idle should be bottomed out at around 108. That's a very easy & quick thing to look for.
If you really suspect the CCP but cannot test it properly, then you can simply unhook the canister from your intake for the emissions test to ensure you are getting no extra vapor from the tank.
Old Mar 2, 2013 | 12:30 AM
  #244
TPI_BLAZER's Avatar
Car: 1986 K5 Blazer
Excellent idea...will just have to make it appear as if its hooked up...simple.
Old Mar 2, 2013 | 11:18 AM
  #245
TPI_BLAZER's Avatar
Car: 1986 K5 Blazer
Went to local PAP...todays loot:
91' Caprice canister with purge valve and pigtail, $30....retail $150+ Ill probably do the block off like 350sbc did, but at least I have it if needed.
A few other odd and ends....Windstar fans and a few switches. Will put lights inside grill on floor switch and with the window-tank selector, Ill do my window and wire another accessory..porbably more lights.
Definately need the dash trim as I have nothing there now..
Old Mar 2, 2013 | 07:03 PM
  #246
TPI_BLAZER's Avatar
Car: 1986 K5 Blazer
OK, new CCV on...this is how it should look:
I still need to wire the pigtail...cant find any dead leads? Wires from the pigtail are green-pink/black stripe. I did find blue-pink/black stripe...? Would be green-blue be the same if the can is from a Caprice?
In the meantime I will just block the ccv-tb line as suggested by 350sbc. Just put in a coupler that I filled with scilicone...for now, keep everything appearing oe.
Old Mar 4, 2013 | 09:13 AM
  #247
Engine: Lb9
Transmission: M20
On the wiring polarity will not matter. I would bet if the wiring is still there its tucked under your dash. F7 dark green/yellow uses the ecm to control the ground side of the solonoid. on the fused powerside the stock harness tied together theair solenoid and egr solenoid and hot side of the check engine light. i know where there is a junction block lol
Old Mar 4, 2013 | 10:13 AM
  #248
TPI_BLAZER's Avatar
Car: 1986 K5 Blazer
....on the fused powerside the stock harness tied together the air solenoid and egr solenoid and hot side of the check engine light.
Im gonna have to dig around the EGR soleniod and make sure that is even hooked up...or would I be experiencing specific symptoms?
....i know where there is a junction block lol.
Was just there yesterday Got board and made an adjustment to my aux lighting...pics later today.
Old Mar 4, 2013 | 12:24 PM
  #249
TPI_BLAZER's Avatar
Car: 1986 K5 Blazer
Yup. I had my aux lights behind the grill jimm'ied are were hot off the batt with an in-line fuse. I put them on the dist block with a relay and in-line fuse...
...and went old school with a foot switch I snagged at th yard this wekend.....
Old Mar 4, 2013 | 12:26 PM
  #250
TPI_BLAZER's Avatar
Car: 1986 K5 Blazer
So I peaked at the ECM and if Im looking at the right connector....its not there.
It also looks like Im missing: M/T shift light...I have Auto no biggie
Port Switch solenoid...?
Converter Divert Solenoid...?
