Simple Coolant Temp Sensor Question
Old Jan 15, 2013 | 07:00 AM
insomniac's Avatar
Car: 1991 Firebird Convertible
Engine: 5.7 L98
Axle/Gears: 3.45 9 Bolt Posi
Simple question:
Can the CTS be bad and cause issues yet read what seems to be a correct temp on the scanner? Is it normal for the CTS while fully warmed up to read about 185-195 yet the engine temp gauge read 220-230? I know they are 2 different sensors and the engine temp gauge is by the headers but is 40 or so degrees too much of a difference?
Old Jan 15, 2013 | 03:29 PM
tpi84stepside's Avatar
Re: Simple Coolant Temp Sensor Question
If one of the issues you are talking about is hard starts...Yes. It happened to me but it wasn't the sensor itself. It was the ECM. Everything was reading about 25* too cold. Check the voltage at the plug. It should get 5 volts.
Old Jan 15, 2013 | 03:38 PM
insomniac's Avatar
Engine: 5.7 L98
my problem is cold start erratic idle, surges, stalls if i snap the throttle ect. then its a hard start after the stall
Old Jan 15, 2013 | 03:42 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Discription of a bad Oxygen sensor.
Old Jan 15, 2013 | 03:59 PM
insomniac's Avatar
Engine: 5.7 L98
yeah but im talking cold start in open loop so isnt the o2 sensor out of the picture? when the car warms up and goes into closed loop it runs great
Old Jan 15, 2013 | 05:01 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Any codes?
If as you state the engine runs fine when in closed loop and the O2 is working then that would also indicate
the CTS ( at least when warm ) is working correctly.
Maybe it is reading wrong when cold?
Meter the CTS terminals when cold to see if the ohm figure relates to what they should be
http://www.chevythunder.com/cts_diagnostics.htm
http://www.chevythunder.com/cts_diagnostic_pg2.htm
Old Jan 15, 2013 | 05:06 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Is it normal for the CTS while fully warmed up to read about 185-195 yet the engine temp gauge read 220-230? ?
My past experience ( assuming a correctly functioning CTS ) is that the gauge reading is usually the more inaccurate of the two , esp with age.
Only way to confirm true temp at the sender location is with a heat gun or a mech temp gauge connected temporarily
Old Jan 15, 2013 | 05:40 PM
insomniac's Avatar
Engine: 5.7 L98
No codes temp matches mat when cold on scanner.
Old Jan 16, 2013 | 07:46 AM
insomniac's Avatar
Engine: 5.7 L98
hmm maybe its something with the IAC, however it was a brand new OEM...
Old Jan 16, 2013 | 08:26 AM
How about compared to ambient temperature when cold? If it's reading warmer then ambient that could make for hard starts.
Old Jan 16, 2013 | 08:28 AM
insomniac's Avatar
Engine: 5.7 L98
ambient temp this morning was about 55
Old Jan 16, 2013 | 08:49 AM
How does that compare to the temperature on the scanner?
Old Jan 16, 2013 | 08:50 AM
insomniac's Avatar
Engine: 5.7 L98
spot on
Old Jan 16, 2013 | 08:59 AM
Doesn't sound like your problem is your CTS then does it...I would go thru the adjustment of the tps and iac again and see what happens. It might just need to be cleaned out. They can build up a lot of carbon.
Old Jan 16, 2013 | 10:19 AM
DJP87Z28's Avatar
That was my opinion also. So as a last resort, I changed the O2 sensor ($20.00 Part) and my problems were solved. At first start up good idle, no stalling, no hesitation and runs great Cold & Hot. I should have changed that part years ago but kept looking elsewhere to no avail.
Old Jan 16, 2013 | 10:37 AM
insomniac's Avatar
Engine: 5.7 L98
wow, makes no sense but thats what im gonna do next....
would your car work good in closed loop when warmed up as well before you changed the o2?
Old Jan 16, 2013 | 11:44 AM
DJP87Z28's Avatar
When it warmed up it was allright in a sense. I was running rich, gas mileage went south and it did stall with the A/C on when in reverse. Otherwise it was good but not great. Like you I chased a lot of things before I said what to H--- and changed the O2 sensor which was 10 years old.
Old Jan 16, 2013 | 11:45 AM
insomniac's Avatar
Engine: 5.7 L98
im gonna give it a shot
Old Jan 16, 2013 | 11:49 AM
insomniac's Avatar
Engine: 5.7 L98
the o2 sensor was new last april, when the car was put together, but shortly after i had a injector get stuck open and melted the cat..... big mess... needless to say maybe the o2 got fouled
TheExaminer
Aug 26, 2015 04:59 PM
redmaroz
Aug 16, 2015 11:40 PM
bamaboy0323
Aug 15, 2015 07:20 AM
fonzie85
Aug 13, 2015 11:50 AM
