Adjustable fuel pressure regulator
Old Jan 18, 2013 | 01:52 AM
the blur's Avatar
Is Holley still the best AFPR ?
I need something complete, with the diagham, gaskets, etc, etc.
Old Jan 18, 2013 | 01:59 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Adjustable fuel pressure regulator
Don't know about the best but the Holley unit is by far the easiest to adjust when installed
Old Jan 18, 2013 | 09:41 AM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Holley is the easiest one to use. No trying to get a small open end wrench under the plenum to turn the adjusting bolt. Not to mention the clearance issues because of the adjusting bolt on top of the regulators. Just turn the dial by hand on the Holley.
Old Jan 24, 2013 | 09:01 AM
Pat Hall's Avatar
One word of caution on the Holley ones. Don't know if the issue has been resolved recently, but the Holley regulators have been known in the past for the diaphragm rupturing really easily. It's a shame too because, as said above, the **** makes them really easy to adjust. The housing on them is really nice too. I have a Holley one, but I chickened out on using it due to the above issue of the diaphragm rupturing prematurely. I ended up using the Crane unit on mine, and even though it uses the bolt instead of a ****, I still have enough clearance to adjust it even with the Super Ram intake. I'd suggest either the Crane unit, or the BBK one. Btw, the Crane one requires re-using your stock diaphragm. I think the BBK units come with a new diaphragm. Of course it's not too expensive to buy a new replacement diaphragm from any parts store.
Old Jan 24, 2013 | 09:19 AM
the blur's Avatar
Then would it be best to buy the Holley regulator and a diaphragm from somewhere else ?? Anyone have a link to a diaphragm?
Old Jan 24, 2013 | 09:27 AM
Pat Hall's Avatar
Not sure if the Holley uses the same type of diaphragm as stock ones. I'd have to go take my Holley one apart and see if it's the same.
Old Jan 24, 2013 | 09:37 AM
ninetyone's Avatar
Axle/Gears: 3:42
Never had a problem with the holley
Old Jan 24, 2013 | 11:13 AM
Fred SS's Avatar
Car: 87 Monte Carlo SS
Engine: 89 350TPI Transplant
Transmission: 2004r
I agree with Pat, I bought a Holley AFPR, intalled it and the motor sat for a few months before firing up. Once I fired the motor up, I checked the vacuum line to the regulator, it was full of gas. The diaphragm ruptured. Shame, I did like the ease of adjustment.
MustangBeater20
Oct 29, 2022 09:20 PM
9192camaro
16
Feb 3, 2019 12:21 AM
wayshegoes
Aug 17, 2015 12:00 PM
89-S-dime
Aug 12, 2015 11:57 AM
Kaweh
Aug 9, 2015 02:54 PM
