3.1 V6 Idling issues?
Old Jan 25, 2013 | 10:08 PM
K_Gunn2128's Avatar
Car: 1991 Camaro RS
Engine: 3.1 V6
Transmission: Automatic
I bought a 1991 Camaro 3.1 v6 TPI two years ago out of a barn. As to be expected after staying in that barn for so long, rats had chewed wires under the hood and a few parts had gone bad... after working on the car for nearly a year, it was ready to drive.. or so we thought.
After I started driving the car on a regular basis, I noticed that it had an idling issue, especially during the hottest part of summer. As long as you're going down the road the car runs fine, but if you have to stop at a stoplight the RPMs start bouncing up and down, anywhere from 500-750 RPM. Unless you hold it on about 1500RPM, it will eventually flutter and die.
This issue has just about driven us crazy. It seems almost like it's flooding; the cooler the air is, the better it runs. We've tried changing the temperature coolant sensor and it seemed to do better for a while, but now (er, when I parked it for the winter) it's back to square one.
Sorry for such a long post. Any advice would be greatly appreciated... A friend mentioned that it could be the computer? Never messed with fuel injection much, so it's safe to say that we're a little lost.
Old Jan 25, 2013 | 11:08 PM
musicfreako's Avatar
Car: 89' camaro RS TTOP
Engine: 92 5.0tpi Bosch III, headers, msd
Transmission: 700r4 built. trans go. 2,300 stall
Axle/Gears: 3:73 posi ls disc brake conversion
Re: 3.1 V6 Idling issues?
Codes? My maf sensor on my old v6 caused these symptoms. It took sat for years.
Old Jan 26, 2013 | 05:14 AM
fasteddi's Avatar
Car: 1991 Camaro RS
Engine: Lq4 6.0 SBE s485 turbo E85
Transmission: Fsi th400 stage 4. TSI 5500 st
Axle/Gears: Strange S60 4:10s
Hope on over to the V6 part of this froum. May find alot more help over there.
A 3.1L is a MFPI Multi fuel port injection.
Old Jan 26, 2013 | 08:08 AM
K_Gunn2128's Avatar
Car: 1991 Camaro RS
Engine: 3.1 V6
musicfreako: I've never had it scanned... Where is the sensor?
fasteddi: Didn't know there was a v6 board. Thanks for the tip.
Elephantismo
Feb 13, 2019 12:51 AM
cking99
Sep 22, 2015 11:33 AM
mscf
Jan 21, 2002 08:15 PM
drt-rcr
Aug 27, 2001 06:57 AM
9D1BURD
Jun 22, 2001 10:26 AM
