GSS294M vs GSS340M
Car: 1989 IrocZ
Engine: 421 Dart Stroker
Transmission: 4L60E Cahall Performance Built
Axle/Gears: Midwest Chassis Fab 9/ 3.55 gears
GSS294M vs GSS340M
Seems racetronix now offers this pump to replace the tried and true 340M. How does the 294 stack up to the 340M. I have the 340M now bit was looking at the aeromotive stealth unit as well. Its prob a walbro as most are rebranded and repackaged. Anyone been reserching this stuff?
Re: GSS294M vs GSS340M
The AM pumps are not made by Walbro.
We now offer a 340LPH pump as well BUT the factory FL98 lines and wiring will NOT support it.
Car: 1989 IrocZ
Thanks. I have a few questions for you in regards to my fuel system. I have the factory sender, but the feed is converted to teflon 6an feed all the way to the rails throught a fuel labs filter. Rails have been drilled out in the front factory feed to remove the restrictor that the factory feed went through and inhibits cross fuel flow to passenger rails. The feed now feeds through the cold start bung. Return is modifyed to right off the regulator base to a 6an teflon to the frame rail then the factory return line I upgraded one size up, thinking 3/8. Seeing the only stock pieces I still have are the sender and its wiring. Anything you offer to so I could use your 340 in my tank? Thank you for supporting this forum and our years.
Additionally you must have these items to support the power requirements of our new RXP340M pump:
You will also require these parts to install the pump:
A -6 Teflon feed and 3/8" steel or Nylon return is fine for this pump's volume assuming you do not have any hidden restrictions in your system.
Pete's 89 GTA
May 14, 2011 04:13 PM
Orr89RocZ
Jul 11, 2009 10:01 AM
FASTERTHANUMARK
Feb 10, 2009 04:39 PM
92GTA
Nov 4, 2008 02:30 PM
