oil seeping from oil fill cap on valve cover
Old Jan 16, 2013 | 09:16 AM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
one thing at a time, i guess, but now i have oil pissing out of the oil fill cap on the valve cover (stock)... when it was discovered, i was running a breather on same valve cover vs. pcv valve in an effort to determine if oil was going in to the intake via the pcv. since i don't want to hook the pcv back up just yet, i then ran a "vent hose" out of the pcv port to isolate the oil coming from it or the cap. it's coming out of the cap and pools up on the cover... never had this issue before, but anymore i'm not surprised by anything that pops up on this car... those caps are just a screw-in cap, but i never looked to see if it has a gasket on it or not... never had to think about it.
Old Jan 16, 2013 | 09:23 AM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: oil seeping from oil fill cap on valve cover
I think they have a O-ring.
When you put breathers on the valve covers it takes away the small amount of vac in the crankcase system an that can cause leaks.
Old Jan 16, 2013 | 10:05 AM
Anti-Venom's Avatar
Car: '89 Formula WS6
Transmission: 700r4/T56
Axle/Gears: BW 3.23
I do seem to remember an o-ring on them.
PCV is a good thing. I would still run it, just add in a catch can.
Old Jan 16, 2013 | 10:06 AM
Car: '91 Z28
Axle/Gears: 323's
thanks - makes sense to me. i will check the cap for an o-ring when i get home and hook the pcv up to it, as well. i'm about done isolating the potential "oil induction" issue anyway. appreciate the response...
Old Jan 17, 2013 | 09:17 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Oil pissing, that is good. It's a phrase I use frequently. Let us stop pissing around and get something done. So on and so forth, what you pissing around for?? It is better to be pissed off than pissed on. **** just has a ring to it. Sorry for babbling.
Old Jan 22, 2013 | 09:04 AM
Car: '91 Z28
Axle/Gears: 323's
yes, and we are done pissing... once i put the pcv back to the correct configuration, "pissing" out of the oil fill cap stopped. imagine that. and apparently that was my overall oil "pissing" issue, too, as there are no more "****" drops anywhere. but initially i had to "vent" it instead to be sure no oil was being ingested in to the intake thru there. should never happen, but stranger things have happened... i did, however, use clear tubing so i could see if any oil is going thru there... a few more odds-n-ends to check on it and time for a dyno run.
Old Jan 22, 2013 | 09:28 AM
Edwardgp's Avatar
Engine: 454-350
Thank you for making me lol.
Old Jan 22, 2013 | 10:44 AM
TTOP350's Avatar
Oh **** off
Old Jan 22, 2013 | 01:48 PM
Edwardgp's Avatar
Engine: 454-350
And I thought it was to cold to ****, should really be snow.
Old Feb 1, 2013 | 04:51 PM
88I-ROC's Avatar
Car: 1988 Camaro Iroc-Z
Axle/Gears: 3.08
I had similar issue, mine didn't leak bad, but it did leaked enough to mess the valve cover. I tried replacing the cap for used ones 2 times, and it still leaked. I eventually bought a new ACDelco cap, they have a new design for it, and it helped.
MoJoe
Sep 24, 2015 09:12 PM
NBrehm
Aug 25, 2015 11:49 PM
db057
Aug 22, 2015 08:17 PM
1985chevydude
Aug 20, 2015 12:29 AM
mustangman65_79
Aug 8, 2015 01:18 AM
