South Bay regulator
Car: 88 Formula, 90 Iroc RIP, 92 RS Sold
Engine: 305 to 350
Axle/Gears: 10 Bolt
Re: South Bay regulator
BBK and Southbay FPR are the same
fairly easy to put on took like 2 hours or so i think you reuse the spring in stock regulator
only bad thing i noticed is that its kinda hard to adjust
and you would need to take off upper intake
need to use open ended wrench due to the fact tat adjustment bolt is very close to the underside of intake i had to remove my map sensor to adjust it easier because FPR is angled
theres been complaints of vacuum hose coming out when trying to remove it as its just pressed in
but once you adjusted its golden i also recommend replacing diapfram a the same time as old one tends to rot away idk whats been done but just fyi
but nice piece it does its job
http://www.jegs.com/i/BBK/129/1714/10002/-1
http://www.southbayfuelinjectors.com...ssure_Reg.html
Engine: 305 to 350
Axle/Gears: 10 Bolt
same thing just easier to adjust due to its flat dial by hand instead of small bolt
alittle more expensive still have to take apart upper intake to install only difference is you can adjust by hand is it better probably not is it easier to adjust fuel pressure yes both does its job
you propbably hear and see good and bad things about both or anything you buy nowadays
i used BBK/Southbay style and it did its job adjust it and leave it yes its a little hassle but ask yourself how many times are you really going to adjust the fuel pressure on your car ?
but one thing is for sure if you do change replace your diapfram
http://www.hawksthirdgenparts.com/pr...djustable.html
https://www.thirdgen.org/forums/tpi/...regulator.html
https://www.thirdgen.org/forums/tpi/...lace-fuel.html
https://www.thirdgen.org/forums/afte...regulator.html
https://www.thirdgen.org/forums/tpi/...-pressure.html
gixxer92
May 18, 2017 11:20 AM
[Sold] Flowmaster exhaust system
Night rider327
Oct 9, 2015 09:25 AM
Night rider327
Sep 25, 2015 04:47 AM
