Car Won't start..HELP!!
Old Mar 8, 2013 | 08:26 PM
Veaceonee's Avatar
Car: 88 GTA Notchback
Axle/Gears: don't know
On my way to work and the car wont turn over..no hiccup (which would indicate fuel pump) or nothing. Pulled the number 1 plug wire and ground it out with a screwdriver, no spark. It was working fine all day, then suddenly (when Im trying to leave for work) it wont start. Any suggestions?? I checked all the fuses and they look fine.
Old Mar 8, 2013 | 08:37 PM
racerx520's Avatar
Re: Car Won't start..HELP!!
check fusible link?
also try the battery connections, IMO these batteries are the worst for connectivity, i'm always having problems it seems.
try turning on the headlights, if they turn on strong, battery connection is good, if theyre dull or not at all, check your battery
Old Mar 8, 2013 | 08:38 PM
Veaceonee's Avatar
battery is good..nice strong crank
Check the pink wire going into the coil- good
checked the pink coming out of coil- good
How do I check if the coil itself is good?
Old Mar 8, 2013 | 09:08 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
You can check the coil primary and secondary resistance but more than likely the icm failed.
Old Mar 8, 2013 | 09:09 PM
Engine: Lb9
Transmission: M20
http://easyautodiagnostics.com/gm_ic...n_module_1.php
Old Mar 8, 2013 | 09:19 PM
Veaceonee's Avatar
went to pull the coil wire out
pulled the distributor cap
and rotor
think i Found my problem..what you think?
Old Mar 8, 2013 | 09:24 PM
Engine: Lb9
Transmission: M20
Old Mar 8, 2013 | 10:35 PM
racerx520's Avatar
3 years ago i went to do cap/rotor/wires cuz it was missing on a cylinder, after pulling everything off found out the cap/rotor/wires were still all original at 160k miles
Old Mar 8, 2013 | 10:43 PM
Veaceonee's Avatar
Supposedly the engine was rebuilt app. 12k ago. The distributor cap and rotor are MSD parts. How it corroded out that badly so quickly is beyond me. But then again, nothing on this car surprises me anymore.
Old Mar 10, 2013 | 05:12 PM
Veaceonee's Avatar
replaced cap and rotor. Still no start. Went to check the coil, terminal to ground is bad. Went to check the pick up coil in the distributor, the connector just fell apart. So, looks like i need a new coil and distributor.
Old Mar 10, 2013 | 11:00 PM
cerhart's Avatar
Car: berlinetta
Engine: Lt1
Transmission: t56
Go gm hei can't get anymore reliable imo
Old Mar 11, 2013 | 04:54 PM
Veaceonee's Avatar
Got into the distributor today.
here is the pick up coil
and whats left of the Pole Piece
I am going to change the module out while it is apart, because it IS apart. Only thing staying original is the gear and housing.
Old Mar 11, 2013 | 08:56 PM
Veaceonee's Avatar
Bought all new parts today (about $20 shy of a reman distributor), put it all together. Runs like a champ once again.
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
ZsTransAm
Aug 11, 2015 07:30 PM
ryanz281988
Members Camaros
Aug 8, 2015 06:45 AM
kyle5647
Aug 7, 2015 03:08 PM
