Removing Baffles From Air Filter Boxes??
Old Mar 9, 2013 | 02:33 PM
CamaroGuy73's Avatar
To anyone who has actually done this...I have read on here people who have done this and noticed a difference I am wondering how long your filters last after doing this? And if it affects the driveability in rainy wet weather? Seems to me your filter would get wet. I am thinking about instead of cutting entire bottom off, cutting slits in the bottom for more air?
Old Mar 9, 2013 | 03:09 PM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Re: Removing Baffles From Air Filter Boxes??
Very common mod. Many even ad ducts to the grille, Hawks even sells them.
You would have to get your car in a lot of water before it would suck it up, at that point, you'd be screwed anyway.
Old Mar 11, 2013 | 10:28 AM
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
I've removed the baffles and cut little windows out of the air box .. didn't notice much difference but then again it probably is hard to notice if it makes a difference.
Old Mar 11, 2013 | 01:06 PM
VincentZ28's Avatar
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
Cut the whole bottom out. You will see a noticeable difference. Also install K&N filters.
Old Mar 11, 2013 | 01:48 PM
I'll try that this summer thnx
Old Mar 11, 2013 | 01:50 PM
chazman's Avatar
Transmission: World Class T-5
Axle/Gears: BW 3.45
Yup. Half measures don't seems to do much.
Old Mar 11, 2013 | 03:21 PM
yaj15's Avatar
Car: 1988 IROC-Z
Engine: L98 - full intake & exhaust boltons
Transmission: Bowtie 700r4, 2400 rpm stall
Axle/Gears: Borg-Warner 9bolt, 3.45 gears, posi
I have done this mod to my car. I gutted the factory air boxes so that there isnothing beneath my K&N air filters. I also installed the hawks ram airboxes. There is a noticeable difference even on a stock car at all rpm ranges.
I've ported my plenum, SLP intake runners and edlebrock base to match. I'vealso got a 52mm throttle body as well. I'm still running the factory L98 headsand cam. I've also got aftermarket exhaust from the headers on back.
Those gutted air box mods made a big difference when I got around to upgradingmy intake. My car pulls hard now to 5,500rpm and doesn’t loose a lot of steamafter 4,500 like it did with the stock set up. Also from idle to 3,500rpm thereis a big gain in torque as well.
Old Mar 11, 2013 | 04:35 PM
Guest
Guest
Posts: n/a
Filters won't get wet, they will last the same length of time.
uhhhhh......
-no, I did not read the responses
Old Mar 11, 2013 | 05:41 PM
yaj15's Avatar
Car: 1988 IROC-Z
Those baffles are there more for noise reduction than anything else. I haven't had any problems with water, rocks, etc. getting in my setup.
The intake track noise would be more noticible with a car that was still running the factory exhaust.
I'm running an aftermarket exhaust that is a lot louder than the factory setup but, the little extra noise dosen't bother me.
Old Mar 28, 2013 | 09:31 AM
white1991rs's Avatar
Car: 1991 Camaro RS/1989 Formula
Engine: 5.0 L03 V8
I'm considering this mod as well, if the purpose of the baffles is noise reduction what kind of effect does removing them have on the noise? also does anyone know where I can find more info on the aluminum ram air boxes and removing the baffles? I tried searching for it but I never have much luck with the TGO search.
Old Mar 28, 2013 | 09:55 AM
yaj15's Avatar
Car: 1988 IROC-Z
The baffles are there for noise reduction and keeping water away from the MAF. The intake noise after the baffles is removed is more noticible if you are running a stock exhaust system. The stock exhaust on these cars is very quiet and it's easier to notice intake changes then if your running an aftermarket system. It's not a big change in the sound but you can hear more air getting sucked in.
I haven't had any problem with water or any other road contaminents getting sucked in to the intake.
Check out the link below for the ram air boxes.
http://www.hawksthirdgenparts.com/pr...Air-Boxes.html
Attached Thumbnails Removing Baffles From Air Filter Boxes??-stock-tpi-air-box   Removing Baffles From Air Filter Boxes??-stock-tpi-air-box   Removing Baffles From Air Filter Boxes??-modified-tpi-airbox-1.jpg
Old Mar 28, 2013 | 10:00 AM
Car: 1971 Camaro
Engine: 427
It will make it a little louder under full throttle.
Hawks sells premade ducts.
On the tho home page under tech articles is a how to as well.
Old Mar 28, 2013 | 03:44 PM
VincentZ28's Avatar
It's making more power across the board. You will pick up 3 tenths and 3-4mhp in the quarter. The engine wants o breathe
Old Mar 28, 2013 | 04:05 PM
Buggy Disaster's Avatar
Car: 91' Z28. 70' Dune Buggy
Engine: LSX Cam/Full Bolt ons
Axle/Gears: 4.10
I removed the baffles and noticed a nice difference. The filters have no adverse effect as far as getting wet or dirty.
I later installed ram air using AC ducting and noticed a bigger difference in performance. There is still no adverse effect to the filters.
White91rs here are some pics, they are by far not the greatest, but it gives you a solid idea.
Cut on right, stock on left.
Also I used AC ducting, which cost me bout $15. To me it was a better idea than spending 100 plus shipping for the hawks boxes.
Old Mar 29, 2013 | 11:21 AM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
I first cut out the baffles, then later I modified my air filter lid into a high flow unit following the thread titled "high flow air lid". I used plastic and two part cement that I bought from a local plastics company and a pipe coupler from a local irrigation supplier. The job took some time and work but I was able to add 5/8" of height in the thinnest area where the lid crosses over the radiator support. My hood still closes just fine. Then, I made ram air boxes from aluminum sheet from the hardware store. They turned out really well. My engine is extensively modified and I noticed the difference immediately.
On a side note, the sound you now hear from the ram air boxes is air being drawn through the throttle body. People ask my if I'm running a blower.
Old Aug 22, 2018 | 10:52 AM
VincentZ28's Avatar
A decent old thread to bring back for the newbies.
Old Aug 22, 2018 | 11:14 AM
Drew's Avatar
Don't forget to mount a couple PC cooling fans for the added RAMJET effect at low speeds and to cool that incoming air. That way you can have Cold Air Intake and RAM AIR IV!!! Lose another 5/10ths with this one simple mod.
Old Aug 22, 2018 | 12:41 PM
chazman's Avatar
Axle/Gears: BW 3.45
Joking aside, biggest bang for your no-buck is opening up your airboxes and bumping initial timing on a TPI.
Old Aug 22, 2018 | 06:59 PM
Drew's Avatar
Prove it. Let's see someone take an otherwise stock TPI car to the track and run several times back to back with a stock and an open air box, and several alternating runs wiith the timing stock and advanced, then post the numbers. Because to date, I've yet to see any actual quantifiable measurements to show the quantity of bang for the no buck.
Old Aug 22, 2018 | 07:08 PM
chazman's Avatar
Axle/Gears: BW 3.45
Well, I'm certainly not going to prove it for you!
But, there were plenty of old magazine articles that proved it at the track back when the cars were new. Didn't we just have someone post an '87 350 Formula, driven by DeFeo, which did just that?
Old Aug 22, 2018 | 08:01 PM
SirReveller's Avatar
Car: '89 'ROC
Engine: 5.7L
Def on my to-do list. Have to change the nose badge anyway :P
Old Aug 23, 2018 | 12:01 AM
Galaxie500XL's Avatar
Car: 1988 IROC-Z
Transmission: T56 swap ongoing
Axle/Gears: 2.77 9-bolt Posi
It’s certainly a better mod than relocating the air filter under the hood, and calling it a “cold” air intake...
Old Aug 23, 2018 | 07:08 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
i dyno’d stock arap bin vs aujl on my mild L98 withstock tpi and saw no difference in peak hp despite the big difference in timing between the two. However it was back to back pulls and might be heat soaked, so hard to say. However it seemed snappier at part throttle but def too much timing with arap imo and needs 93 oct.
stock fbody L98 timing is pretty conservative so small gains in overall curve power can be there. Mainly drivability feel
Old Aug 23, 2018 | 07:26 AM
Car: 1988 IROC-Z
Well, maximum airflow isn’t difficult to calculate...assuming 100% volumetric efficiency, which isn’t likely, a 350 cubic inch engine can use as much as 564 cubic feet of air per minute at 7,000 RPM.
Looking at my OEM setup for TPI, I have serious doubts that the air cleaner ducting can’t handle this amount of flow, and more. I’d say if there’s any real restriction to airflow on my ‘88, it would be at the MAF.
I don’t doubt it sounds better, but significant gains in power do seem pretty unlikely.
Old Aug 23, 2018 | 08:41 AM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
What do you consider "significant"?
Looking at one mod, and seeing tiny gains, and calling it 'a waste of time' because of that...... You might just as well not do anything to your car at all. The engine is, after all, a SYSTEM, and improvements in one part, are complimented by improvements in other parts. Everything works together. Even if you only see a half-horsepower gain, it is STILL a Gain. Do a bunch of those, and you start getting into 'significant' territory. Not to mention, all those little improvements will STILL help when you do MAJOR improvements as well. (heads, cam, intake, etc.)
Old Aug 23, 2018 | 08:56 AM
chazman's Avatar
Axle/Gears: BW 3.45
Exactly. Pennies and nickels turn into quarters.....
Old Aug 23, 2018 | 09:00 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Gutted maf on a mild heads cam 270’s whp tpi build was worth nothing. Surprisingly it did read a few g/s more airflow at wot but did not translate to more power. Did not gut filter boxes tho
3.5” maf and cold air intake did nothing at the track vs gutted tpi air box with homemade ram air using a gutted stock maf on a hot 383 tht went 11.40’s at 119 mph
stock tpi air system is pretty good. I would def do ram air ducting. It works on ls1 cars and seems to work on tpi motors as well
Old Aug 23, 2018 | 12:16 PM
Drew's Avatar
Except a nickel and three pennies isn't a quarter.
Old Aug 23, 2018 | 12:22 PM
chazman's Avatar
Axle/Gears: BW 3.45
Ha! 8 cents is 8 cents!
Old Aug 23, 2018 | 12:35 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
I did a lot of the "tricks" back in the day (early to mid 90s) . Even on the birds a makeshift RA system was worth a couple tenths at the track and it was repeatable. Put it on- car picked up, take off -car slowed.
On the Dyno you won't see a difference because the RA system needs the pressurized air at speed to make the power. Like a mini supercharger.
With my bird, Bumping the timing, RA, 160 t-stat/fan switch and fuel PSI (with knock sensor unplugged gained me ET and MPH. (with factory chip)
Old Aug 24, 2018 | 09:12 AM
BovineZro's Avatar
Car: '91 Camaro Z28
Engine: L31 5.7
It's funny that this thread was brought back - I'm in the process of doing this exact mod! Although in my case, I'm using the gutted TPI intake and Y piece to bring air to a carb hat (similar to what this person has done; that's not my car). Planning on fabbing my own ram air boxes as well, since I've already pulled out my fog lights.
I figure it has to be better than pulling hot engine air into a top-mounted circular air cleaner, right?
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
specialized
Jun 18, 2022 09:26 AM
Derick15
Sep 17, 2016 05:28 PM
