Rocker Arms and Studs
Old Mar 9, 2013 | 06:14 PM
dctrouant1995's Avatar
Car: 1988 pontiac trans am
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
I have a 88 Trans Am with the LB9 in it. I plan on upgrading to 1.6 ratio rockers. From what I have researched, will these fit? http://www.summitracing.com/parts/scc-scp1036bl. Also the rocker arm studs, does the 88 have the press in studs? Or do I just need to pull a valve cover off and find out? Do i need to swap to screw in studs if I put 1.6 RR? Also what screw in studs do I need? How hard is it to install them? Thanks
Old Mar 9, 2013 | 06:53 PM
GTA matt's Avatar
Car: 1990 GTA/1989 Iroc
Engine: L98/383
Transmission: 700r4/t56 magnum
Axle/Gears: 9"
Re: Rocker Arms and Studs
Yes, those will work. You have press in studs, no you do not need to change them to screw in if only doing a rocker arm swap. A good bit of machining is involved to properly install screw in studs.
Old Mar 9, 2013 | 09:44 PM
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
Alright cool, yea I pulled the valve covers off and they got the stupid press in studs but owell. But thats good that I don't have to change the studs
Old Mar 9, 2013 | 09:46 PM
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
I am putting an LT1 cam in it
Old Mar 10, 2013 | 03:03 AM
formula forever's Avatar
Car: 91 formula
Engine: 350 tuned port. bolt ons
ive just ordered the same set of rocker arms. Only thing im nerves about his how durable they are and how well they hold up on a street car. btw good cam choice for your 305.
Old Mar 10, 2013 | 09:05 AM
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
Ive been reading about them and eveybody says something different so hopefully they'll be great for a daily driver. I'm hoping it will be. I think I have the 350 cam though, so I doubt I'll see much of an improvement, but hopefully I will
Old Mar 10, 2013 | 11:41 AM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
To run an Lt1 cam ,along with 1.6 rockers you need to change your springs. Too much lift now. You can run the stock cam with 1.6 rockers.
Old Mar 10, 2013 | 02:39 PM
Engine: None
Transmission: None
Axle/Gears: 10 Bolt
Yes, I am going to change the springs to these: http://www.summitracing.com/parts/cca-981-16
Hotrodboba400
Dec 10, 2019 07:07 PM
TX-SleeperC5
Feb 24, 2016 01:34 PM
New2Chevy
Sep 28, 2015 12:35 AM
ericjon262
Sep 11, 2015 06:07 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
