Quick spark plug question
Old Mar 14, 2013 | 02:52 PM
whitecomet's Avatar
Car: 1987 Pontiac Firebird formula 350
Engine: sbc 355 tpi
Axle/Gears: 3.27 posi 9 bolt b/w
I believe the oem spark plug reach is .460" however, do i absolutely have to run that plug reach? its stock L98 heads on a 355 cid with flat top piston i think 10.5:1 compression ratio.
Old Mar 14, 2013 | 03:16 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Quick spark plug question
What would you run instead?
Old Mar 14, 2013 | 03:27 PM
whitecomet's Avatar
Engine: sbc 355 tpi
i wanna run a shorty ngk or ac del. plugs but the only ones i have found are either .375" or i could get a .750" i have hedman headers 68460 i was running the u groove accel ACC-8199 but they really do foul up rather quick.
Old Mar 14, 2013 | 03:53 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
A shorter reach won't extend into the chamber and the charge will take longer to burn. A difference of .085" probably isn't the end of the world, though.A longer reach will extend too far into the chamber where the piston face might hit it, and when the exposed threads foul with carbon removing the plug could be difficult without damaging the threads in the head.
Old Mar 14, 2013 | 05:49 PM
whitecomet's Avatar
Engine: sbc 355 tpi
that makes sense. Could anyone reccommend a good shorty spark plug with .460" in. thread reach? or should i just try another type of shorty accel plug?
evilstuie
Feb 28, 2016 03:33 PM
69 Six Pack
Oct 5, 2015 07:51 PM
Red iroc-z 305
Sep 30, 2015 05:22 PM
Bryan F
Aug 18, 2015 02:28 PM
