TPI car-CARB engine
Old Mar 17, 2013 | 07:24 AM
stevek's Avatar
Car: 1989 GTA
Engine: 5.7 /360
Transmission: turbo 350
Axle/Gears: stock
TPI car-CARB engine
My new project(89GTA) came with factory 5.7 MPFI and I am trying to decide which way to go with this build. I have the built 350 in my 82Z and have decided to use it as my donor parts car. The Z is really rough but lots of new stuff and this GTA is REALLY nice as far as body and interior goes. The guy gave me a complete 305 he was going to try to put in it and the original injection system and the computer is intact...here's the question. I am trying to decide if it will be easier to adapt the GTA to a carb or switch my 350 to injection(my 350 is out of a 69 Camaro and am pretty sure the FI won't fit right) All the computer control stuff is what bothers me and some fuel deliverer issues will need to be addressed as well if I go carb. I have a resistor key but could swap out Camaro lock if stay carb. Thoughts? Major concerns, pro or con for one over another? Thanks
Old Mar 18, 2013 | 04:48 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: TPI car-CARB engine
Your carb motor will slip straight in under the 305 TPI intake
You install a 350 chip in the stock '89 computer and a 350 knock sensor
Depending on the engine mods you may need a custom tune
The cam ( how lumpy ?) you have in the carb motor is the only thing that may cause a problem with EFI
Old Mar 19, 2013 | 06:04 AM
stevek's Avatar
Car: 1989 GTA
Engine: 5.7 /360
Axle/Gears: stock
284h Comp cam. This sounds like a no brainer if all I have to do is what you suggested. The guy took a hammer to one of the air runners and dented it up pretty bad and I was wondering if that would affect air flow enough to notice. Thanks for the info
Vintageracer
Jan 10, 2020 05:33 PM
Caspar
Jun 19, 2016 11:19 PM
R3500
Aug 17, 2015 12:16 PM
Sanjay
Aug 12, 2015 03:41 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
