maf vs map?
Car: 87 iroc-z
Engine: 355 tpi
Axle/Gears: 4.10
maf vs map?
my buddy gave me a tpi setup that came with no maf sensor , is there a way to tell the difference?
thanks justin
thanks justin
Engine: 4++,350 & 305 CIs
Re: maf vs map?
Yup.
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: maf vs map?
Difference in what?
You can run a MAP intake with MAF computer or a MAF intake with MAP computer so what setup
the intake came off originally is irrelevant
All TPI parts are the identical year for year ; a 90-92 MAP plenum has the MAP sensor shown below
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: maf vs map?
TTOP350 did answer your original question in post #1 exactly. That type of answer means he's tired of reading between the lines to try and figure out what you want to know. The actual question you were asking was quite obviously "HOW can a MAF/MAP be identified?". He's taking a stand on demanding concise written english communication. Personally, I found all those 9th grade writing assignments extremely boring, but it turns out that clear communication without any unnecessary BS is actually quite useful. The little bit of time you spend organizing your thoughts will put you on the fast track to accessing the deep pool of knowledge available on this website.
Re: maf vs map?
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Re: maf vs map?
You sure about that?
Car: 82 Z28
Transmission: T400
Car: 1971 Camaro
Engine: 427
Re: maf vs map?
The part I highlighted, all
parts are all identical year to year.
Runners changes, tb's changed, etc....
There are a few differences between the two systems.
BumpaD82
Feb 26, 2016 02:57 PM
