wanting more hp.
Old Mar 18, 2013 | 10:16 PM
92z28rockinmaro's Avatar
wanting more hp.
http://www.hawksthirdgenparts.com/pr...-Polished.html
would this tpi stealth ram intake make a big change in hp? anyone have this setup? im currently running a stock tpi setup with new injectors, lunati cam, dart heads, and some new rockers.
Old Mar 20, 2013 | 12:39 PM
tenpin842's Avatar
Car: 1987 Trans Am
Engine: 5.0L TPI
Axle/Gears: Richmond 3.73
Re: wanting more hp.
stealth ram would help out a lot I would think. Specially if your running a stock TPI set up. I'm running an Elelbrock set up on my car.
I would swap it out...or do some major porting on your stock set up.
Old Mar 20, 2013 | 01:16 PM
thewhitestripes's Avatar
Car: 1988 iroc
Engine: 350 tpi
Transmission: t-5
Axle/Gears: stock
From what I've heard they rob you of a little low end torque while opening up the upper rpms and shifting the power band. Your intake is definatly your choking point as it sits right now though. I went with slp runners and had the plenum, runners, and manifold ported and I'm happy with it. There is a write up some where around here that campares different intake set ups. The stealth ram and my set up were dead even I think in terms of hp.
Old Mar 20, 2013 | 01:36 PM
neeb_usmc's Avatar
Car: 1985 Trans AM
Engine: 350 ATK Performance
Axle/Gears: Eaton 3.73
Yea I'd get it or port your TPI. Mine is currently being installed as we speak. You can find it a lot cheaper than the price though through summit or jegs. A member here is selling a brand new polished one for 550 or get the regular one for under 400 w/I fuel rails
Old Mar 24, 2013 | 01:27 PM
thanks guys for the input, that will be my next buy for sure!
krisner89
Carburetors
Sep 20, 2015 08:56 PM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
E Rod
Aug 28, 2015 05:17 AM
86White_T/A305
Aug 17, 2015 12:16 AM
89-S-dime
Aug 12, 2015 11:57 AM
