89 TPI open loop
Old Mar 24, 2013 | 09:02 PM
dan68rs's Avatar
Car: 89 formula
Engine: tpi 350
Axle/Gears: 95 z 3.42
89 TPI open loop
Im having trouble with my 89 iroc, its staying in open loop, i put a new o2 sensor in it and checked that i had continuity between the sensor and the computer and i did, the only problem i noticed was that the tps voltage read by plugging in the laptop and using tunerpro is lower than the actual voltage at the tps, i was wondering if that is why it would be staying in open loop. i have checked the coolant temp sensor and it is fine. i guess the only other idea would be the computer is bad just thought i would ask before getting a new computer.
Old Mar 24, 2013 | 11:15 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Re: 89 TPI open loop
Are you checking the 02 going down the road or sitting in the driveway at idle?
Old Mar 25, 2013 | 11:01 AM
dan68rs's Avatar
Car: 89 formula
Engine: tpi 350
tried both, i end up getting a o2 sensor code.
Old Mar 25, 2013 | 11:10 AM
TTOP350's Avatar
Whats the code?
Has the motor/manifolds/exhaust been modified at all?
Old Mar 27, 2013 | 08:57 AM
dan68rs's Avatar
Car: 89 formula
Engine: tpi 350
its a 350 block with 305 ho heads, all stock other than that. i cant remember the code number i will pull it again in a day or so.
Old Apr 4, 2013 | 03:33 PM
dan68rs's Avatar
Car: 89 formula
Engine: tpi 350
getting code #13
Old Apr 9, 2013 | 11:01 AM
dan68rs's Avatar
Car: 89 formula
Engine: tpi 350
ok turns out it was bad o2 ground for the computer. fixed and all good now.
bamaboy0323
Sep 3, 2015 06:07 AM
beast94
Aug 20, 2015 06:44 AM
wruiz
Aug 13, 2015 09:07 PM
Sanjay
Aug 12, 2015 03:41 PM
