porting heads
Old Mar 28, 2013 | 04:58 PM
blkgta88's Avatar
porting heads
Is it worth it to port the stock iron heads on an 350 Tpi
Posted from Thirdgen.org App for Android
Old Mar 28, 2013 | 05:02 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: porting heads
http://www.powerblocktv.com/episodes...r-power-how-to
Old Mar 28, 2013 | 07:05 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: porting heads
In my opinion if aftermarket heads are available then I would just get better heads. If you're adamant about doing it just make sure you have a backup plan in case of failure. I play with Datsuns. There are no aftermarket heads available for them. So I'm either stuck with the stock castings or I have to port them.
Old Mar 30, 2013 | 12:35 PM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Re: porting heads
Yes, if you are on a budget, hav a mild build ,and know how to port.
MoJoe
Sep 24, 2015 09:12 PM
italiano67
Aug 31, 2015 06:04 PM
Brendankup
Aug 30, 2015 01:46 PM
355tpipickup
Alternative Port EFI Intakes
Aug 29, 2015 10:47 PM
86White_T/A305
Aug 17, 2015 12:16 AM
