cams
Old Mar 30, 2013 | 05:40 PM
lazey8's Avatar
Car: 1989 Trans am
Engine: LB9
Transmission: auto
Axle/Gears: 2.75
cams
could someone give me some ideas on a good cam for my stock lb9 and what to expect when installing it
i want a aggressive cam but want to keep the stock converter
Old Mar 31, 2013 | 03:53 PM
Cosmik Debris's Avatar
Re: cams
I think that what Mr Blaze is saying in his own humourous way is that no such thing exists. In order to use an agressive cam other things have to be changed as well. You will need to improve the heads, intake, exhaust etc, and then you won't be able to use a stock convertor.
You are going about things in the wrong way, first decide what you want to do with the car in terms of performance and drivability etc, secondly choose components to achieve it. Heads, intake etc should be chosen and then a cam to suit.
Old Mar 31, 2013 | 03:55 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: cams
More importantly, with an aggressive cam you can't use the stock computer either.
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
