want to block off egr, any advice
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: want to block off egr, any advice
There are pros and cons. The egr lowered the combustion temperature and during highway speeds it leans out the fuel mixture and timing will advance increasing fuel milage. The bad the code 32, but it also seems like a engine without a egr the plenum stays cleaner.
Car: 1987 Trans Am
Engine: 355 tpi
Transmission: 5 speed
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
and will advance the spark at the same time as when it "thinks " the EGR has been operated
Excess spark advance in non EGR conditions can cause problems
The error code only shows that the ECM has not "seen" the EGR operating when it told it to ; it won't stop the ECM from trying to operate it
Engine: Lb9
Transmission: M20
Thank you Andrew, far making it for me. There is more than just the code 32 like vetteoz says function needs to disabled as well.
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Not too mention, you can not pass Federal emissions standards without an EGR valve in place.
Car: 88 GTA "Cocaine"
Engine: 350 tpi
I am thinking that I might just keep it. but I am getting my prom reprogrammed so i would have got it disabled.
is there any performance gain in getting rid of it?
Engine: Lb9
Transmission: M20
No performance gains deleting the egr.
Car: 1990 T/A
Engine: 5.0 TPI
Axle/Gears: 373 posi
So my AIR pump went bad and I removed it. Do I have to remove anything or block off anything like the pipe attached to the pump? I just want to get it running for the time being. I will strip everything off later.
TIA
Geoff
TIA
Geoff
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
It's not emissions legal to remove it.
But you'll need to block off the injection tubes on the manifolds and the cat. Should also have a chip burned to eliminate the AIR enabled 100mv O2 sensor output offset.
Car: '89 GTA 9,000 MILES
Axle/Gears: 3.27 9 bolt
Old post I know.
Going to block off the EGR valve opening in middle of TPI intake ?
Where did other egr tube blockoff go ? Guess our TPI cars dont have
this egr tube ? Was that only on Corvettes ?
Engine: Lb9
Transmission: M20
Egr external feed is on corvette only. Tpi f body gets the feed from a internal passage in the passengers side head.
Engine: Lb9
Transmission: M20
No problem, feel free to send me a pm if you have any tpi related questions or reprogramming questions.
So our 3rd gens do not have the port but Corvettes manifolds do so Im assuming an Edelbrock TPI intake will have this port to work with either car ? If so another small reason for me to stay with the stock manifold and port it...stealth too.
Engine: Lb9
Transmission: M20
The corvette manifold and edelbrock Accel ect has duel feeds for egr. One in the rear and one in between the intake ports on the passengers side head. Either feed will work they connect to each other.
Engine: Lb9
Transmission: M20
You can see the passages on this image here.
Not a bad deal for a edelbrock base too
https://www.thirdgen.org/forums/engi...ower-base.html
theshackle
Mar 5, 2017 06:37 PM
New2Chevy
Sep 28, 2015 12:35 AM
