No start
Old Apr 19, 2013 | 01:34 PM
Astrozombie81's Avatar
Car: 88 Iroc Z
No start
So ive been trying to adjust my idle using the walk though. when i unplug the IAC after fully extending it, the engine fails to start. I then have to remove the IAC place the pindle all the way retracted and reset my ECM. the car will start but idles at 2k rpm. I have a 88 305 TPI, stock. any suggestions? thanks in advance.
Old Apr 20, 2013 | 02:03 PM
86T/A_Ram_Air's Avatar
Car: 91 Trans Am
Engine: 355 TPI
Transmission: Built T-5
Re: No start
this will happen sometimes, can you get it to start by open the throttle up?
Old Apr 23, 2013 | 07:09 AM
EvelBist's Avatar
Car: 89 Black GTA
Engine: 'close to' stock 5.7 but trending>>
Transmission: 700
Re: No start
when the pintle is extended and then the iac connector is disconnected during the setup procedure, you'll be relying on the throttle position screw only for air flow, so it may be really low. try tweaking the throttle position open a bit by having someone hold it open slightly while youre trying to start the car.
also, adjust the tps to the correct .56v setting. and once its running, check for vacuum leaks.
Orr89RocZ
Apr 25, 2016 08:28 AM
Wade787b
Sep 29, 2015 01:15 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
92camaroJoe
Aug 13, 2015 06:07 AM
86Base
Aug 8, 2015 01:34 PM
