TPI Throttle Body TPS Bolts
Car: 88 Iroc Z
Engine: 5.0
Axle/Gears: G92
Hi
I am in need to finding replacement TPS Torx bolts that screw into the Throttle Body.
I have already went to ACE/HomeDepot and others, to no avail.
It appears these are not standard thread/size and GM no longer has them.
-Doc
-Doc
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: TPI Throttle Body TPS Bolts
place a ad in the classified wanted section They are 4.5mm not a common size.
2.8 V6 F-bodies use the same screws on their TPS
Car: 88 Iroc Z
Engine: 5.0
Axle/Gears: G92
Thanks for the information. I am on a CL search atm. I drive this car daily, truck is currently down.
~Doc
~Doc
Terrell351
Jun 13, 2021 01:13 PM
