Which injectors to buy?
Old Apr 25, 2013 | 04:21 AM
Ray 350 Formula's Avatar
Car: 1989 Firebird Formula
Engine: 5.7
Transmission: Automatic
Hi Group it has been a long time since I have been on here. I need to replace my injectors on my 1989 Formula 5.7. Even though the car has only 44,000 original miles with some mods I was told the electronics went bad in them. I plan on selling the car so was wondering if the GB remanufactured ones would be okay. Thank you for any help and will put car in For Sale Section soon.
Raymond
Old Apr 25, 2013 | 06:36 AM
gta_knight's Avatar
Car: 1987 GTA
Engine: 350 TPI w/ extras !
Re: Which injectors to buy?
Hi mate,
I think the best ones to get are the Bosch III ones, south bay injectors will see you right
Old Apr 25, 2013 | 08:51 AM
lonestar7's Avatar
Car: 1988 Firbird formula 350
Engine: 5.7L TPI
Axle/Gears: 3.27 Nine Bolt
+1 on the Bosch III injectors. I put them on my Formula 350 and I'm happy with them.
Old Apr 25, 2013 | 09:25 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Southbay and the Bosch 3's have my vote
Old Apr 25, 2013 | 01:02 PM
ASE doc's Avatar
Car: 87 IROC Z28
Engine: 355 cid TPI
Transmission: Custom Built 700R4 w/3,500 stall
Axle/Gears: QP fab 9" 3.70 Truetrac
Southbay is good to deal with and great prices too. Discounts for TGO members.
Old Apr 25, 2013 | 01:44 PM
fireburdluvr85's Avatar
Car: 91 formula ws6
Engine: 355 tpi OBDII
Transmission: 4l60E
Axle/Gears: 2.73 with 4th gen brakes
Excellent service all the way around.
Old Apr 26, 2013 | 06:35 AM
EvelBist's Avatar
Car: 89 Black GTA
Engine: 'close to' stock 5.7 but trending>>
Transmission: 700
whats GB?
I just installed Bosch 3's, rebuilt from FIC. Southbay is great too. Either way, if you have the oem multecs, 1989 was a bad year for them (they arent ethanol tolerant). New injectors should make you smile.
Old Apr 27, 2013 | 03:27 AM
Engine: 5.7
GB is a brand that sells remanufactured injectors. Original injectors in car hard to believe with only 44,0000 original miles the electronics went bad.
Old Apr 27, 2013 | 09:33 AM
Engine: Lb9
Transmission: M20
The stock Multecs coil windings are cooled bye fuel. The coating on the windings are effected with the ethanol and causes the coil windings to short out and may shut off your injector driver in the ecm and stop all injector pulse. Throw them in the garbage
Old Apr 27, 2013 | 10:41 AM
southbay08's Avatar
Hi all, thanks for the thumbs up!!
Ray 350 Formula if you decide to purchase from us,we will do our best to help you in any way. If you have any questions or concerns, give us a shout.
Old Apr 28, 2013 | 09:28 PM
gbettner's Avatar
From: Close to Boggstown Indiana ( out in the middle of a corn field)
Car: 89 Iroc, saved from scrapyard
Engine: 350 vortec w/stealth ram
Transmission: 85 corvette 700r4
Axle/Gears: 3.73 posi
Bought a set from south bay a couple weeks ago. Great deal and great service.
Old May 26, 2013 | 11:29 PM
danclemts's Avatar
Car: 1985 Volvo turbodiesel
Engine: 1989 305 TPI in the Volvo
Transmission: 1990 700r4
Axle/Gears: 3.73 Dana 30
I just put the Bosch 3's in my 89 305. Car was only running on 7 cylinders, found out #1 wasn't firing. Switched injector plugs and it was plug dependent not injector. Figured I had a bad injector connector, got the noid light out and it tested fine. Turns out the contacts on the connector were not making a good connection to the injector prongs. bent the contacts inside the connector and all good. heads up for you guys
Car runs smooth and strong now.
Old May 27, 2013 | 10:50 AM
TFS355S10's Avatar
Car: Today? 98 GMC Sonoma
Engine: Seriously? The Sonoma has a TPI 305
Axle/Gears: 7.625/4.10
I just received my Bosch 3's from South Bay Saturday. Put 'em in last night, but haven't started it yet due to the transmission being apart. I'm hoping for an 8 cylinder ride this time... LOL
South Bay shipped mine fast too, so that was a plus.
Street Lethal
Apr 30, 2019 12:14 PM
italiano67
Dec 11, 2016 09:21 AM
New2Chevy
Oct 4, 2015 11:27 PM
Thornburg
Aug 27, 2015 08:33 PM
tmellott89
Aug 16, 2015 02:58 PM
