cam option
Old May 11, 2013 | 05:28 PM
eduardocastrejo's Avatar
Car: 80 transam, L98 vette and camaro
Engine: 5.7L98
Axle/Gears: 3.07
cam option
Please help me to choose properly the camshaft
1991 L98 automatic 2.59 rear end
I already bought some parts
Mods
Trans and rear end
1.-2200 stall converter (bought it, not installed)
2.- 3.07 rear end (bought it, not installed)
3.- transgo (bought it, not installed) and oil cooler
4.- beam plates (bought it, not installed)
5.- speedo gears, red,green 92 sensor for 3.07 (bought it, not installed)
6- nitto treadwear 100 installed
engine
1.- Long tube headers installed
2.- no cats, doublé 2 1/4 exhaust to borla mufflers installed
3.- 3 wire heated 02sensor installed
4.- 1.6 rr self align installed
5.- stock L98 aluminum heads and stock 48mm throttlebody
6.- edelbrock ported base manifold (bought it, not installed)last purchased ítem
7.- lt4 springs (bought it, not installed)
8.- 30 lb injectors (bought it, not installed), I red that 24 is enough but pcmforless suggested 30lb
9.- walbro 255 fuel pump (bought it, not installed)
10.- k&n,cutted airlid,adjustable fuel pressure regulator installed
11.- msd 6al installed
12.- moates apu1 for fine tuning installed
13.-pcmforless chip not boughted until buy cam (baseline)
14.- egr, frisbie,airpump deleted
originally I wanted 180cc afr heads,268xfi cam and superram but im out of funds for this Project then I want to use the parts that I already have it.
superram difficult to found and expensive, then probably I will buy slp runners (ported)
heads, I will use stock heads unported,unmachined then .525 of lift is the limit, (maybe one day , I will (afr 180cc)
cam options: I want to use my 1.6rr
1.-lt4 hotcam with 1.6rr
24502586 218/228 .492/.492 .525/.525 112deg
probably to much for stock heads ,tpi, 3.07 gears
I red that valves float with lt4 spring then I will need other springs
2.- comp 264hr12 with 1.6rr
08-302-8 210/220 .480/.480 .512/.512 112deg
looks like a good cam for torque from 1500 to 5400
this cam with 1.6rr is like the comp 8-304-8 266 cam with 1.5rr
3.- cam suggestion ?, any advice ?
Old May 11, 2013 | 05:51 PM
Johnny Blaze's Avatar
Car: 1971 Camaro
Engine: 427
Transmission: TKO600
Re: cam option
What cam does comp suggest?
I'm building similar, only with ported 083 heads, and ported stock base/ ported slp runners.
I am using a 501 series comp cam with 1.52 rockers.
Are tout machining the heads for the lift? I've always heard .480-.495 was the typical limit.
Old May 11, 2013 | 10:20 PM
3rdgenZ's Avatar
Car: 1985 Z28
Engine: 85 L98
Axle/Gears: stock 10 bolt-3.73 eaten posi
Re: cam option
with those gear and converter id go with the 210/220 comp. anything over 480 lift will require you to mechine the head for valve seal clearince.
sounds like a soild setup.
Old May 12, 2013 | 02:25 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: cam option
Originally Posted by eduardocastrejo
4.- beam plates
You got a F-Body or a Corvette ????????????
Fill in your profile so people know what car you have
1.-lt4 hotcam with 1.6rr .525/.525
If you are talking about a VETTE L98 engine (on a 3rd Gen Forum )
then the factory alum 113 heads you have on your L98 will take the LT4/ZZ4 springs as a no mod , drop in fit
and give you the recommended spring that GM supplies in the LT4 cam and 1.6 rockers you seek to use.
Old May 12, 2013 | 06:50 AM
Car: 1971 Camaro
Engine: 427
Re: cam option
I just figured "beam plates" was a funny name for subframe connectors?
A vette would explain the odd rear gear ratios too I guess.
Old May 12, 2013 | 09:59 AM
Engine: 5.7L98
Axle/Gears: 3.07
Re: cam option
hi,
thanks for your answers
yes, c4 vette l98 113 heads stock
i already have the lt4 springs
Old May 14, 2013 | 02:44 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Re: cam option
For your edumacation
http://www.zfdoc.com/c4beamplate.htm
(A problem F-Body owners don't have )
italiano67
Dec 11, 2016 09:21 AM
RedLeader289
Jan 22, 2016 03:05 PM
camaro71633
Sep 1, 2015 10:24 AM
Brendankup
Aug 30, 2015 01:46 PM
ZZ42Fast
Aug 10, 2015 08:20 PM
