Advancing timing on 350tpi
Old Jul 14, 2012 | 09:14 PM
Black88Z's Avatar
Car: 1988 IROC-Z Camaro, 1981 Trans Am
Engine: 350 TPI, 301 N/A
Transmission: 700r4, 350thm
Hi, i know the stock timing is 6* btdc. I have never checked timing, and i have an overheating problem (checked/replaced all the usual suspects), so im going to check my timing.
Is there a better degree to time it to? I read somewhere on here that you can advance it a few degrees but im not sure to what point. (engine is fairly stock, just bolt on parts for now )
Will this help or hinder gas mileage?
Old Jul 14, 2012 | 10:26 PM
Damon's Avatar
Re: Advancing timing on 350tpi
My experience with near-stock TPIs is that you can bump it up about 4* over stock (10* BTDC, using factory base timing procedures) for a little boost in power with little or no downside.
Can't say it make the engine run and hotter or colder than before, but it certainly liked the extra advance. We're talking "playing in the margins" kinds of difference in terms of the load it puts on the cooling system here. If you're flat-out running hot a couple degrees one way or the other isn't going to make a "holy cow!" kinda difference.
Old Jul 14, 2012 | 10:46 PM
Black88Z's Avatar
Ok, cool. Thanks Damon. It sounds like you've done this a few times, what do you think i should set it at? Did you notice the best results at a certain degree?
Old Jul 14, 2012 | 11:07 PM
cuisinartvette's Avatar
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
on a stocker my car slowed down putting more timing in it going from time slip to time slip
General got it right imo. Others will have different opinions
Old Jul 14, 2012 | 11:18 PM
Black88Z's Avatar
Im not sure what your saying, it got slower? Do you have results showing that or you just think it did? Thats odd tho..
But General got it right? What do you mean?
Old Jul 15, 2012 | 12:33 PM
Axle/Gears: 4.11
Thats pretty much what the post said
Old Jul 15, 2012 | 02:31 PM
Black88Z's Avatar
The post didnt make much sense thats why i asked, and that one still didnt answer my question. But its fine, ill just play with the timing and see how it goes.
Old Jul 15, 2012 | 04:48 PM
MedVader's Avatar
Car: 90 Formula hardtop
Engine: 5.0 TPI
General = GM. He's saying the factory pretty much got the advance as good as it gets. You're not going to pick up much trying to play with the timing on a stock engine.
Old May 14, 2013 | 07:40 AM
insomniac's Avatar
Car: 1991 Firebird Convertible
Engine: 5.7 L98
Axle/Gears: 3.45 9 Bolt Posi
maybe im crazy but i just added 2* over stock and i feel a difference... but my car is modded and again maybe im crazy...
Old May 14, 2013 | 07:54 AM
Guest
Guest
Posts: n/a
Don't forget the high octane-
nhra-trans-am
Southern California Area
Sep 17, 2015 10:16 PM
1989formula5.7l
Aug 15, 2015 11:35 AM
Armored91Camaro
Aug 12, 2015 09:41 AM
Thirim
Aug 9, 2015 06:19 PM
djmarch
Aug 9, 2015 05:27 PM
