fuse next to battery ???
Car: 88 Iroc ls1 swap
Engine: ls1
Transmission: 4l60e
Axle/Gears: original disc
Is thee a power wire that goes to the battery other than my starter wire and my alternater wire. Doin a swap and cant get power to my fuel pump please help thank you...!!!
Car: 83 Trans Am
Engine: 350 Carb'd
Re: fuse next to battery ???
on my car there was a pigtail off of the + battery wire that powered the fuel pump relay. from what ive read there was a fuse inside the connection of the pigtail. my fuel pump went bad sitting during the swap so i just switched to a mech pump. i do remember that before i hooked up the pigtail i had no power on the orange wire of the relay however.
Car: 1987 IROC-Z Camaro
Engine: 305 LB9
The fuse near the battery is for your fuel pump. I have no idea why GM put it there instead of with the rest of the fuses.
Engine: ls1
Transmission: 4l60e
Hmmmm cause I have a harness but theres a female connecter but dont know where it goes..I think the male would have a power wire to the battery then to the female connecter but I dont know how it looks like
Engine: ls1
Transmission: 4l60e
Okay so can I just power this fuse and my fuel pump shouls work.. im goIn to cut on side of the fuse and put direct power will this work.. ??? Thanks for any help
Engine: ls1
Transmission: 4l60e
Come on any help please from all the wires that go towards the battery which one,should I cut and place to power.... thanks..!!!
