No power to fuel pump..????
Old May 15, 2013 | 11:00 PM
irocdls1's Avatar
Car: 88 Iroc ls1 swap
Engine: ls1
Transmission: 4l60e
Axle/Gears: original disc
Cant get power to my fuel pump but I put power to terminal g on my aldl and the pump runs does thos mean anything need some help...
Old May 16, 2013 | 04:25 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: No power to fuel pump..????
That everything to the pump is fine.
Have you checked for power at the pump relay? orange wire should have 12V all the time
Does the pump relay actually work?
At the OP switch ? It also should have 12V all the time
Does your OP switch actually work ?
Glowsock
Jul 24, 2025 03:15 PM
midge54
Dec 27, 2019 04:14 PM
Brcharrelson
Aug 26, 2015 07:47 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
