Call For TPI Dyno Results
Old May 24, 2013 | 08:47 AM
rwstegne's Avatar
Car: 1989 Iroc Z 5.7L
Engine: 5.7L
Axle/Gears: built 4.10s
Thirdgeners, would you help me to fill out this excel spreadsheet with different TPI motor combinations / setups? If you send me the information I will roll it up. Personally, long term, I would like to document the successes of these TPI setups on the thirdgen.org’s Technical Articles page just like the information on cam shafts. I have seen information/spreadsheet on the web for carburetor setups but nothing for TPIs. Would you guys help me to create this?
Updated spreadsheet with the first thirdgener response:
1. Shaun - aliceempire - Thanks!
2. TPIVette - Thanks
3. torqueaddict - Thanks
Who is NEXT ?
File Type: zip
Old May 24, 2013 | 10:40 AM
Javier87z28's Avatar
Car: 1987 Camaro Z28, 1989 TTA #922
Engine: lb9, 3.8L turbo
Transmission: 700r4, 2004R
Re: Call For TPI Dyno Results
Bump for ya man
Old May 26, 2013 | 08:33 AM
rwstegne's Avatar
Engine: 5.7L
bump
Old May 26, 2013 | 07:12 PM
rwstegne's Avatar
Engine: 5.7L
Added another
Old May 28, 2013 | 10:15 AM
rwstegne's Avatar
Engine: 5.7L
Who is NEXT ?
Old May 29, 2013 | 09:54 AM
rwstegne's Avatar
Engine: 5.7L
Who is NEXT ?
Old May 29, 2013 | 10:02 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Pm dyno don, kevin91z, 1989gtatransam, vincentz28
Or search for posts by these guys
Old May 29, 2013 | 08:37 PM
RS Chris's Avatar
Car: 1991 RS
Engine: 5.0
The Cali guys have some impressive TPI cars.
Old May 30, 2013 | 06:46 PM
aliceempire's Avatar
Transmission: T-5, TH350, T-5
You may want to check with watajob too. I think he has the peak numbers on his signature so a dyno sheet may be available.
Old May 31, 2013 | 11:08 AM
rwstegne's Avatar
Engine: 5.7L
New updates today and I will PM those guys. Thanks for helping
Old Feb 6, 2014 | 05:24 PM
rwstegne's Avatar
Engine: 5.7L
Who is NEXT ?
Old Feb 7, 2014 | 10:37 PM
VincentZ28's Avatar
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
Cant get in the file
Old Feb 8, 2014 | 08:34 AM
rwstegne's Avatar
Engine: 5.7L
Let me know an e-mail address and I can send the excel file straight to you.
I was able to download the zip file. Maybe you need a zip file software, there are free ones online.
or
Here are the items from each column of the spreadsheet. If you send me any of the information I will input it. Also, let me know what you think of the format/columns. Just trying to create a general cookbook if you will for TPI motors so people have an understanding of the potential of a TPI if the right combines are chosen. Hoping if I get good input and format, maybe a member will add it to the tech section of this forum.
Car
Disp. (cu. in.)
Naturally Aspirated
Intake setup
Intake Base
Runners
Throttle Body
Injectors
Heads
Camshaft
Camshaft Duration @ 0.050" Lift
Camshaft Lift (in. @ valve)
Rockers
Headers
Pistons
Rods
Crankshaft
Fuel Pump
Distributor
Timing
Comp. Ratio
Transmission
CAT
Gears
Maximum Horsepower
Maximum Torque (lb.-ft.)
Dyno Available
1/8 mile
1/4 mile
1 mile
Mileage City
Mileage HW
Old Feb 13, 2014 | 01:35 PM
rwstegne's Avatar
Engine: 5.7L
bump
Old Mar 18, 2014 | 10:03 AM
rwstegne's Avatar
Engine: 5.7L
some updates
Old Mar 28, 2014 | 07:21 PM
rwstegne's Avatar
Engine: 5.7L
more updates
Old Jan 18, 2016 | 10:43 AM
rwstegne's Avatar
Engine: 5.7L
Making progress:
247.5rwhp and 333.4rwtq SAE corrected
Here is a list of the differences from my previous
-T56 swap
-SLP runners
-built 3.08 10 bolt Locker
-Hedman Headers and Y-Pipe
-Mufflex with Magnaflow Muffler -
-CS144 Alternator Upgrade - http://sethirdgen.org/cs144.htm
-Heated 3 Wire O2 Sensor - wow, best idle improvement.
-255 Walbro fuel pump and racetronix wiring kit
-minus MSD 6A digital - have to send it out for repair
While fixing a head gaskets and intake leaks plan to do a few upgrades hoping to get free HP and MPG.
Netted 36.1 rwhp 17% and 35.1 rwtq 12% improvement
Old Jan 18, 2016 | 09:10 PM
Originally Posted by rwstegne
Making progress:
-T56 swap
-SLP runners
Well, you've been busy. Sounds like a really nice ride now.
Old Jan 18, 2016 | 09:54 PM
rwstegne's Avatar
Engine: 5.7L
I am hope once I install the 3.73 Yukon gears in my garage it will be a nice ride.
Then once I rebuild the original 160,000 motor it will be a great street car, only if I could figure out the motor combination, that was the reason I tried to create this string. LS? TPI? Miniram? Procharger? Turbo?
Old Jan 19, 2016 | 12:32 AM
ht4100's Avatar
Car: 86 Z28, 86 Seville, 98 Isuzu Rodeo
Engine: 383, HT4100, & 3.2 V6
Transmission: World Class T-5
Axle/Gears: G92 3.23
86 z28
Disp. (cu. in.) 383
Naturally Aspirated yes
Intake setup tpi
Intake Base ported stock by high flow fuel injection-iowa
Runners AS&M long tube
Throttle Body TPIS 58mm
Injectors 24lb ford blue top
Heads brodix ik180
Camshaft comp xfi
Camshaft Duration @ 0.050" Lift 268/280
Camshaft Lift (in. @ valve) .520/.515
Rockers 1.6 roller rockers
Headers hooker shorty
Pistons speed pro hyperutectic
Rods stock 350
Crankshaft scat-engine kit was from northern auto parts
Fuel Pump from racetronix, the higher psi one
Distributor MSD 8366
Timing-Stock I think
Comp. Ratio 9.77-1
Transmission World Class T-5
CAT-gone
Exhaust- single to muffler, aftermarket, flowmaster
Gears 3.23
Maximum Horsepower
Dyno Available 280rwhp/350rwtq on mustang dyno
1/8 mile
1/4 mile
1 mile
Mileage City
Mileage HW
Old Jan 19, 2016 | 12:34 AM
ht4100's Avatar
I had the car for 15 years, but sold it last summer, moved on to other cars.
Vintageracer
Jan 10, 2020 05:33 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
backtothe80s
Sep 5, 2015 12:39 AM
85Iroc-Z
Aug 13, 2015 01:58 AM
Sanjay
Aug 12, 2015 03:41 PM
