TPI on my 350
Old Jun 10, 2013 | 05:22 PM
ToolGuru's Avatar
Car: 1969 Camaro SS
Engine: 355, roller, Profilers, FIRST tpi
Transmission: 200r4
TPI on my 350
I had a tpi unit along time ago and got rid of it. Now I've got the bug to be a bit different than all the other bellybutton 69 Camaros out there with a carb and a 14 inch air cleaner.
My engine is a 350 bored .030 over. Flat top pistons, four eyebrow reliefs, not sure if block was decked. Should be 9.75:1. 041 heads pocket ported. 1 5/8 dia full length headers. Cam is a Comp Extreme Energy 262. 218 & 224 @ .050 with .470 lift. First generation Edelbrock Performer manifold with 2200-2300 stall. 3.42 gears in a corp ten bolt rear.
I can get a nice TPI unit out of a 85 Vetter for $100. Car has always been set up for the street, would love around 425-450 tq at the flywheel. Can this be done with above TPI? What would need to be done to unit? Thanks for your replies.
Old Jun 10, 2013 | 07:00 PM
ninetyone's Avatar
Car: 91' Firebird SOLD
Engine: 350 TPI +bolt-ons
Axle/Gears: 3:42
Re: TPI on my 350
It would require porting the lower base manifold and the runners would have to be replaced.
Old Jun 10, 2013 | 07:02 PM
ninetyone's Avatar
Axle/Gears: 3:42
Re: TPI on my 350
Old Jun 11, 2013 | 02:38 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: TPI on my 350
What Hp does it have at present , with the carb because it will not make that with a stockish TPI ? ( but will have much more torque )
Old Jun 11, 2013 | 06:39 AM
ToolGuru's Avatar
Car: 1969 Camaro SS
Transmission: 200r4
Re: TPI on my 350
Right now it makes about 375 HP.
Old Jun 11, 2013 | 08:23 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Re: TPI on my 350
I'd caution you about using the computer & harness from the 85 Vette. That particular year is a one-year specific computer that is very primitive and there aren't many people that tune them. The 85 Vette also ran a different fuel pressure (35lbs vs. 43 for everything else), and had the external MAF burnoff relay module.
If you're planning to run an aftermarket harness & ECU, then the 85 parts will be fine, but if you want a plug & play option, look for a TPI setup from an 86-92.
Old Jun 11, 2013 | 08:44 PM
ToolGuru's Avatar
Car: 1969 Camaro SS
Transmission: 200r4
Re: TPI on my 350
Yes, from my reading on here that is exactly what I'll do. IF I do this. There are so many conflicting stories out there on what kind of power to expect. Yes, I understand torque is king on the street. My engine probably puts out over 400 ft lbs at the crank now, but at 5300 rpm. Could I expect the same, more, or less if I use that Vette tpi? I am thinking the TPI with my current setup would have a flat torque curve over 400 ft lbs from 1500 RPM to 5000 RPM. Am I off base in this thinking? Will ported and siamesed stock base, ported and siamesed runners , and ported plenum be up to the task?
Old Jun 12, 2013 | 05:31 PM
ToolGuru's Avatar
Car: 1969 Camaro SS
Transmission: 200r4
Re: TPI on my 350
Ahhh, I'm going to pass. After reading post after post, its gonna cost around $1500 at least to have a decent running tpi. I can buy and swap in a LS engine for that kind of dough and have way more power along with injection.
Old Jun 12, 2013 | 08:19 PM
ninetyone's Avatar
Axle/Gears: 3:42
Re: TPI on my 350
idk man, torque is only king from stoplight to stoplight. After about 40 or 50 mph in a tpi car, a car that weighs the same as you but has more hp will win.
Old Jun 12, 2013 | 08:21 PM
ninetyone's Avatar
Axle/Gears: 3:42
Re: TPI on my 350
[QUOTE=ninetyone;5580359]idk man, torque is only king from stoplight to stoplight.
Old Jun 12, 2013 | 08:22 PM
ninetyone's Avatar
Axle/Gears: 3:42
Re: TPI on my 350
Old Jun 12, 2013 | 08:30 PM
ninetyone's Avatar
Axle/Gears: 3:42
Re: TPI on my 350
Old Jun 12, 2013 | 08:31 PM
ninetyone's Avatar
Axle/Gears: 3:42
Re: TPI on my 350
Have you ever thought about a holley stealth ram intake manifold? They only run about $300 for the manifold.
Old Jun 12, 2013 | 08:32 PM
ninetyone's Avatar
Axle/Gears: 3:42
Re: TPI on my 350
Porting will cost a couple of hundred to have done
Old Jun 12, 2013 | 09:46 PM
ToolGuru's Avatar
Car: 1969 Camaro SS
Transmission: 200r4
Re: TPI on my 350
Wow. Can't thank you enough for the string of nonsensical posts and then the link to a jcpenny coupon.
Old Jun 12, 2013 | 09:58 PM
ninetyone's Avatar
Axle/Gears: 3:42
Re: TPI on my 350
Sorry, there is something wrong with my account. It double posted too for some reason? Jc penney coupon? What do you mean?
Old Jun 12, 2013 | 10:02 PM
ninetyone's Avatar
Axle/Gears: 3:42
Re: TPI on my 350
My advice to you is to ditch the TPI manifold altogether. If I had a thirdgen again, that's what I would do. Get a Holley Stealth ram if you want to stick with Fuel injection. You want good advice? You just go it. Thank you
Vintageracer
Jan 10, 2020 05:33 PM
theurge
Aug 21, 2015 12:46 PM
Out-Cast
Aug 17, 2015 10:57 AM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
