Did I buy a defective throttle body?
Old Jun 21, 2013 | 04:21 PM
formula forever's Avatar
Car: 91 formula
Engine: 350 tuned port. bolt ons
just ordered a new holley throttle body. Installed and set idle. I have to push the throttle back down by hand. So if I snap the throttle and let go it will idle at 1,000. Then I go under the hood and push butterflyes closed. It should not feel sticky after new throttle body. The idle adjustment screw is backed off and out of the way.
Old Jun 21, 2013 | 09:13 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Did I buy a defective throttle body?
Installed and set idle. it will idle at 1,000.
You adjusted the IAC ?
Checked for vac leaks ?
Old Jun 21, 2013 | 09:22 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Some of the aftermarket stuff binds or sticks like that. Take the throttle body off and check it for blades binding on the housing. Some very light sanding will fix it normally.
Old Jun 21, 2013 | 10:19 PM
heat seeker's Avatar
Car: 89 Formula
Engine: 383 SBC/HSR
Take a look at the lever that's attached to your TPS, it could be rubbing on the side of your TB. What you're describing is exactly what happened to me, when I bought a new AS&M TB.
I took the TPS off, shaved a little off the lever.....and was good to go.
Street Lethal
Apr 30, 2019 12:14 PM
italiano67
Dec 11, 2016 09:21 AM
mdtoren
Aug 23, 2015 12:52 PM
86White_T/A305
Aug 17, 2015 12:16 AM
mdtoren
Aug 16, 2015 05:45 PM
