fueling a 383 stroker tpi
Old Jul 1, 2013 | 12:27 AM
killerzombie's Avatar
Hey guys. I'm thinking about buying a 383 stroker short block and bolting all my 350 stuff to it. Then buying a 224-230 duration cam and maybe a stall converter. But my question is.. will the combination of a adjustable fuel pressure regulator with stock injectors and ported heads with a stock ecu be able to fuel my stroker the right amount. If so..how much pressure? And if not would the TPIS chip do it justice?
Old Jul 1, 2013 | 03:50 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: fueling a 383 stroker tpi
Stock ECM will be fine but you should get a custom tune for it , not a generic " off the shelf " chip
There are plenty of online calculators you can use to work out required injector size base on Hp expected, fuel pressure , etc
24lb are about the defacto min for a 383 , some run 32lb injectors
Old Jul 2, 2013 | 12:50 AM
Copperhead's Avatar
South Bay recommended 30 lb-ers for my 383, my engine builder predicted around 425 fwhp. Ask them.
Old Jul 3, 2013 | 11:02 PM
southbay08's Avatar
If we can help you in any way, give us a shout!
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
mhatfield 14
Oct 24, 2015 07:48 AM
Reddeath210
Oct 6, 2015 08:20 AM
85Iroc-Z
Aug 13, 2015 01:58 AM
Sanjay
Aug 12, 2015 03:41 PM
